Thinking about my first DIY : Millett Hybrid MiniMax. How hard is it for a first timer?
post-7628242
Thread Starter
Post #1 of 6
LepakVT
Although I could simply buy a used MiniMax, I usually like to stick with new products. So I was thinking of picking up a Minimax kit from beezar.
I've never built a headphone amp from scratch before, but I'd like to say that I'm really adept at following instructions and working with my hands. I build desktop PCs for fun as well as using the toolbox in the garage for any and all projects around the house. I've done some minor soldering before, but nothing that would make me an expert.
I also think this would be a good, fun project to tackle after a day at work. I know I get a lot of satisfaction after building a PC and knowing I built it. For a first timer, how long would you say it should take to successfully complete?
Thanks
post-7628310
Post #2 of 6
tamu
i guess if your careful enough with mains power then it should be pretty straight forward.. It comes with a wallwart anyway
I never built a minimax so I dont know how long would it take but anything between 2-4hours seems long enough
post-7628556
Post #3 of 6
Oberst Oswald
I built the MiniMAX as my first DYI amp and I would say it is a wee bit of a challenge if it will be your 1st one.  I was very careful and still made a mistake with installing the MOSFET's in backwards.  That said TomB will go to the ends of earth to help you if you have problems.  The kits are excellent and a joy to build & listen to but be prepared to "pay your dues" with reading, a proper soldering station and time...it will take a good weekend to complete unless your related to Tom Edison.
post-7628574
Post #4 of 6
iamthecheese
I also built the minimax as my first DIY project, and I also can say TomB was a huge help. My biggest tips would be take your time soldering and check your resistor values before you solder. But, yes it is very doable for a first time DIY'r, especially with how complete the kit is from beezar. Just be prepared to take your time(10 hours would be a good estimate), since you won't get everything right the first time.
post-7628586
Post #5 of 6
Oberst Oswald
Start your reading here...  http://www.head-fi.org/forum/thread/348235/new-millett-hybrid-minimax-what-happened-to-this-thread
post-7628607
Post #6 of 6
LepakVT
Thanks for all of the helpful info but I ended up finding a great price on a used MiniMax so I snatched it up right away.
