ThieAudio Legacy Series IEMs
- Thread starter IEMusic
AmericanSpirit
Member of the Trade: Night Oblivion
After 5 hour afternoon listening with monarch, now I think the undisclosed config of Monarch would be
-1DD (bass)
-2BA (Mid)
-4BA (treble)
-2EST (super tweeter)
Which explains why monarch could handle so much of resolving capability for string and micro details
Oops, legacy thread it was![Face with tears of joy :joy: 😂](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f602.png)
-1DD (bass)
-2BA (Mid)
-4BA (treble)
redrol
Im nearly sure the config is 1DD+4BA for bass, 2BA for mids, 2EST for trebles
AmericanSpirit
Really? Hmm, I may run some bass tracks to testIm nearly sure the config is 1DD+4BA for bass, 2BA for mids, 2EST for trebles
H T T
- May 11, 2013
Sound impressions are at about the 8:40 mark.So the L4 has better separation/sound stage but colder timbre to the L5?
Here is another one. He uses foam tips:
Dobrescu George
Reviewer: AudiophileHeaven
If you're looking for a really good IEM with a natural sound, beautiful design, and excellent support from Linsoul Audio, the THIEAUDIO Legacy 4 should be your guy!
I made a full written review about them, great price / performance ration, good comfort, and I was really pleased with the entire package~
https://www.audiophile-heaven.com/2021/05/thieaudio-legacy-4-iems-the-perfectionistic-midranger.html
![](https://www.head-fi.org/attachments/3881837/)
For everyone owning Legacy 4: Try it with foam tips. I switched to foam only a few months ago mainly because of comfort. I tried XELASTIC, but I realized for me they sound way worse this way. SpinFits sound much better, but with foam it is the best and the most comfortable. Usually I do not have much difference with different tips. Just for reference I do not believe and cables and I usually do not hear much difference with many things suggested on HeadFi, but the tips make a real difference with Legacy 4s for me!
jsmiller58
I will have to try! The L4 are a touch bright for me, so maybe foam tips will hel to dampen that just a bit. Thank you!For everyone owning Legacy 4: Try it with foam tips. I switched to foam only a few months ago mainly because of comfort. I tried XELASTIC, but I realized for me they sound way worse this way. SpinFits sound much better, but with foam it is the best and the most comfortable. Usually I do not have much difference with different tips. Just for reference I do not believe and cables and I usually do not here much difference with many things suggested on HeadFi, but the tips make a real difference with Legacy 4s for me!
Actually, for my taste the biggest difference with foams may be that some of the bass is missing, but the low subbass stays the same? Makes everything more clear. For example drums sound way better this way, since the "rumble" stays but it does not mix with the mids anymore. Probably just better fits my taste that way.
James Shoegazer
Did they managed to fix the ergonomics and fit problems on the Clairvoyance with the Excalibur/Oracle?
Legacy 2 just dropped. Here's BGGAR's review:
Aevum
- May 15, 2007
im really curious if the L2 is a upgrade over the starfield, it seems to do with one BA the job the L3 does with 2,
According to chris, L2 is an upgrade to the already aclaimed fiio fh3 so yeah, seems good. Regarding starfields, they are tuned differently.
Edit: also, beryllium dd bass is![Heart suit :hearts: ♥️](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/2665.png)
Fat Larry
Decided i want custom Monarchs... Linsoul said no :/
IEMusic
Anyone have the Legacy 2 yet, or at least have one order? Looking forward to reading impressions, particularly regarding the beryllium coated DD implementation.
Also, for anyone interested, it is currently on Drop. The price is $99, but “Members who purchase earn 2178 Drop Rewards Points”.
https://drop.com/buy/thieaudio-legacy-2-iem
Total: 6 (members: 0, guests: 6)
