Steve Eddy
Member of the Trade: The Audio Guild
Aka: TempAccount555
- Sep 28, 2003
But what is "ground" to a headphone? At its most fundamental, it's just a coil of wire which has a voltage applied across it and current running through it. What does it know of "ground"?
The post you refer to, when it mentions ground, it's speaking not so much of ground, but rather a common return path shared by the left and right headphone drivers. However, that issue has nothing in particular to do with balanced amplifiers. You may have an unbalanced amplifier in which there is no common return path for the left and right headphone drivers, or you may have a balanced amplifier which does.
It can, but it's not any sort of requirement. I can show you a balanced stereo headphone amp with just two "channels" of amplification.
Yes. But while there may be more going on than a balance of impedances, the simple point of my comment was that that's precisely what the term "balanced" refers to.
se
Originally Posted by Hirsch /img/forum/go_quote.gif Balanced headphones use are not grounded in the usual sense. Both sides of the headphone have active amplification, and the headphone itself is not grounded. |
A balanced stereo headphone amp actually has four channels of amplification. |
So, there's a bit more going on than "balance of impedances, i.e. the impedances of each line to ground" (which is not all that relevant in the absence of a ground) and common-mode noise rejection going on in a balanced headphone rig. |
se
