thebit Opus#1S DAP impressions
post-15278425
Post #856 of 924
Pete7
Has anyone replaced the balanced headphone jack? I'm thinking if I can manage to get the case open to replace the battery, I should replace my f'ed up headphone jack at the same time.
post-15278748
Post #857 of 924
borjok536
when u open the back cover sir, ull find screws on the sides, u can unscrew to expose the board and to remove it, there u can replace the 2.5mm jack.
post-15281366
Post #859 of 924
sashokv36
Swollen battery opened the back cover. Battery still has good parametres, but for how long?
PS. Screws visible :wink:
Hello,
Do you happen to have pictures of battery from the other side? Any markings there, which could be useful?
Many thanks!
post-15281412
Post #860 of 924
borjok536
Hello,
Many thanks!
the markings are covered by the grey tape. when u remove it, u will find the dimension of the battery (755083 or 7.5x50x83 cm), the voltage which 3.7v, 14.8Wh, 4000mah and a series of no which imo is a manufacturing date? correct me if im wrong..
Reactions: sashokv36
post-15281472
Post #862 of 924
borjok536
btw btw anyine has the idea of the appropriate charger to use in charging? someone suggested to use a 2.1amp charger. fast charging imo is not good or anything above 2.1? or something lower would be better?. currently using a hcoo 2.1a.
post-15284538
Post #866 of 924
borjok536
IMG_20191103_095302.jpg thanks, maybe once the batt3ry arrives ill buy a 2.0amp charger..
post-15290714
Post #867 of 924
borjok536
i have received the battery but i havent tested it yet
post-15290794
Post #868 of 924
borjok536
i have already received the battery and tested it, theres one problem though, the red and white wires intechanged, u need to interchanged it to work. so far the battery is working good and changing. ill update in a few more days
Reactions: peter123
post-15290966
Post #869 of 924
Big Kev
The balanced port is faulty on my Opus #2, but when I email them, I don't get a reply. Is their CS really that bad and should I just wait, or are they ignoring me?
post-15290973
Post #870 of 924
Wiljen
TN
TN
Website
audiofool.reviews
You don't mention how long it has been since you emailed. They can take a day or two to respond so expecting a response within the hour is probably going to disappoint,
