Duggeh
Indeed
- May 9, 2005
Earwicker7: Same mechanical principles, different drive system, the AMT as the acronym refers to is like a pleated ribbon driver and is driven with the same sort of electricity that moving coil and ribbon drivers like which is comparitivly high current and low voltage.
The piezo driver in the H2 is folded or pleated like the AMT so it does fire against itself, but rather than a folded ribbon its a folded piezoelectric film and that likes the same sort of electricity which electrostatic transducers like, a comparitively high voltage, low current type.
You'd probably get some sound of them from the AMP 2 with an adapter but the volume would be very limited and you'd get maximum power handling distortion out of them if you tried to feed them more than the few watts they'll be happy with in that scenario.
The K1000 would I think be a better second headphone to try with the AMP 2.
On the AMT front, I'm trying the drivers in a crappy DIY put together using Stax Lambda pads to create a fixed earcup volume for the driver to push against and moving the driver a little closer to the ear in the process. Planar headphones like to push against a fixed volume of air. Very interesting listening.
