A2 = Bifrost Uber USB2
Mo2U = Modi 2 Uber
Ma1 = Magni 1
I tested different ways, always with an amp.
Mo2U-Ma1 vs B-A2 (Fastest test: Advantage of not switching wires and having to tweak the volumes when switching wires)
Mo2U-Ma1 vs B-Ma1 (Switching wires to the one amp, thats why I want to use the A/B switch to speed up this process)
I used Sennheiser HD600's and HifiMan HE-500's for headphones. So there was plenty enough of testing. I did not compare the headphones in these tests as I used one headphone per set of tests.
Observations:
- Maybe the Bifrost Uber was quieter, if so by a whisper. I have to be able to switch faster to one amp to be sure, if at all.
- The B-A2 may have been cleaner on transients of certain music when played very loud, uncomfortably loud. Not a practical advantage and barely noticeable if at all.
In the past I've compared the Ma1 and A2 using a Y cable to the B and a switch to flip my headphones between Amps. I could flip the switch back and forth to instantly switch amps which were matched to the same volume (only needed to do the volume match once). My main motivation was to see if the Magni was brighter (treble) as some folks claimed. It was not brighter. The only observation I could make was the same as in #2 above and that may have been a result of expectation bias.
Conclusions:
- At $300 the Mo2U/Ma2U stack is the deal of the centuary. The non Ubers are probably just as great with less features.
- I'm still keeping my Bifrost because it looks cool, keeps my hands warm in the Winter and is big enough to stack with my A2 on top. I also need two stacks.
- Once distortion levels get to a certain low point, human beings are not as good as test equipment.
- We never see transient distortion specs, I know of no standard for this, anyway.
- These tests are time consuming.
- Schiit makes great Schiit.
I will do some more tests in the future.
If you ask me, us meat popsicles (ask Bruce Willis) are such Bull Schiit artists.
