Isaacc7
- May 27, 2014
Gotta say, I get a kick out of people using tubes engineered for high power output to power headphones. I’m sure the GEC engineers would be confused if they knew their high power tube was being used in single ended triode mode. Mind you, all those engineers probably switched over to solid state once the devices become good enough.
I have finally started using the GU50. This tube is one of the reasons I wanted to be able to use 12v output tubes. There really aren’t that many 12v output tubes that aren’t just 12v versions of 6v tubes so I don’t usually recommend spending the extra to have the abilty to do it. Sure, you can get 12aq5 or 12v6 cheaper than the 6v versions but the most desirable versions of the 6v versions weren’t made with 12v. The GU50 might be reason enough to get the option though, I’ve been really impressed.
The *av5 tubes are supposed to emulate a 2a3 when wired in triode. I do think that the Sylvania 12av5 did a pretty good imitation of a 2a3. I got a lot of the same impressions that I have gotten from 2a3 based amps in the past. I’ve never heard a 2a3 push pull amp before but there is a distinctive clarity and pure tone in the bass that I am getting with the 12av5 in triode. If you believe the internet, the GU50 is supposed to emulate a 300b when wired in triode. I’m trying not to let my preconceptions color my impressions but… What can I say? The audiophile’s mind is an easy thing to influence lol.
I’ve only got about 20 hours the the GU50 so far but they are opening up quite nicely. They are, like the 300b, giving me a presentation that emphasizes naturalness and tonal purity. Brand knew the bass was pretty loose but things have tightened up considerably since then. I’ll continue letting them break in over the next week. Currently driving them with a quad of Raytheon 12j5w GT.
