The Reference 6SN7 Thread
Aug 25, 2024 at 1:53 PM Post #10,276 of 10,650
As far as I know the internals of the amp work as they should with external heater power. All that you did is to disconnect the heater voltage from the amp and instead you are using an external source.
All you need is to ascertain that the current draw from the external power supply exceeds the current draw of the tube.
What's the tolerance voltage wise? I got a fixed supply that runs at 12.25v (1.5a). My variable supply has vanished into the void so I can't check the exact output. I know 7dj8 will happily run at 6v (so will 7n7). Those 14n7 running on 12v?
Aug 25, 2024 at 2:03 PM Post #10,277 of 10,650
An old friend of mine who was active in radio technology in the 50's and onwards told me that a 10% tolerance was perfectly acceptable in vacuum tube production.
According to this a 12.6V tube should work fine between 11.34V to 13.86V.
Aug 25, 2024 at 3:41 PM Post #10,278 of 10,650
All this talk about 7N7 has gotten curious me. Which version do you guys think that I have?
From my observation this has T plates and tall envelope like my Sylvania 6SN7W but without the support rod. Mica shape looks similar and there are 4 umbrella spokes from the top mica too.
Who made that one? Got a pic of the whole tube?
Aug 25, 2024 at 3:43 PM Post #10,279 of 10,650
You mean 6SN7W here, don't you? I have a tall bottle Sylvania 7N7 that sounds and looks like my Sylvania 6SN7A/6SN7W but this doesn't have the copper support rod.
The 7N7 do have a special dynamic to them, they reach out in a 3d like realm of sound. The 7A4 almost the same but those are single triode, you'll need an adapter for double duty.
Aug 25, 2024 at 4:12 PM Post #10,280 of 10,650
Here is a Unicorn 14N7 that I don't remember seeing before:
The markings on the glass are (nothing on the base):
MR
SA96
H 4 on top under the 14N7 designation
MR = Manufacturers Replacement. This dates the tube to 1942-45 when vacuum tubes were rationed and mainly going for military use. A small portion was allocated for civilian replacement use.
SA96 - don't know. Anybody?
H 4 looks like Sylvania codes and could be August 1944.
This is a tall tube and possibly the loctal equivalent of the Sylvania metal base 6N7W. Looks like T-plates and has a single copper support rod with oval bottom ractetrack mica. It sounds excellent!
Yup, as far as I can tell all of the tall 14n7 have the same construction and they sound better than all of the 7n7 varieties. I’m pretty well convinced that the 14n7 is the equivalent of the metal base 6sn7w. The short bottle ones sound the same to me and I can see the copper support rod on a few of them. The getter flashing covers most of them up though. Mind you, only a true 6sn7 cork sniffer like myself think it’s a difference that matters. 7n7 tubes are excellent. I think that the angled plates aren’t as good as the parallel plate.
Aug 25, 2024 at 4:13 PM Post #10,281 of 10,650
Regardless of the brand, Sylvania made that tube. Sylvania made all of the 7n7/14n7 except for the very rare National Union round plate 7n7.
Aug 25, 2024 at 4:15 PM Post #10,282 of 10,650
I had always heard that as well but it’s best to check the data sheets. Not all tubes have as big an acceptable range.
Aug 25, 2024 at 4:16 PM Post #10,283 of 10,650
The 7a4 is a loctal Sylvania 6j5gt. Since the price of Sylvania 6j5gt isn;t all that much it might make more sense to get the 6j5 adapter so you can use other brands as well.
Aug 25, 2024 at 6:54 PM Post #10,284 of 10,650
Might. I have em both. (Adapters) cheap.
Aug 25, 2024 at 6:55 PM Post #10,285 of 10,650
That's what I'm hearing.. was wondering what branding was on his tube.
Aug 25, 2024 at 7:05 PM Post #10,286 of 10,650
14n7.. now that's new to me, that can play on a 6SN7 socket (w/ adapter) ?
Aug 25, 2024 at 7:51 PM Post #10,287 of 10,650
The 14n7 is a loctal 12sn7. You can get an adapter that lets you use an external power supply for the heater. It’s well worth it IMO. I’d get both a 6sn7 to 7n7 adapter and the one you can use an external supply in case you want to use 12v or other oddball voltages.
Aug 25, 2024 at 9:46 PM Post #10,288 of 10,650
If I have 14N7, does it pay to get 14AF7 or 7AF7 tubes?
Aug 25, 2024 at 10:46 PM Post #10,289 of 10,650
Well, they are different tubes so they will sound different. The 14af7 is pretty cheap so if you’re curious it wouldn’t be a very expensive experiment. The two I had didn’t set my world on fire but it does have its fans.
Aug 25, 2024 at 11:19 PM Post #10,290 of 10,650
Thanks - at this point in my tube journey I am only looking for very special great sounding tubes. I found the 14N7 special...
