The Reference 6SN7 Thread
Aug 14, 2023 at 12:16 PM Post #9,166 of 10,669
I too preferred the Melz (1954 and 1973) to the TSRP in my WA22 and sold the TSRP. When I said less euphoric I didn't mean to imply the Melz was inferior, just less rose tinted.
I now prefer the Mullard ECC32 in the WA22.
The 1954 is a wonderful year for the Melz.😉
Oh yeah I was not dependent on how Melz might sound in a particular amp. I designed my own and we used four of them in testing. They were made to show off 6sn7 sound and according to several folks I built them for, I accomplished that goal. 3FBB7A29-1B55-4008-B564-8DFF9DAA9761.jpeg
Aug 14, 2023 at 12:22 PM Post #9,167 of 10,669
I am curious...in general, what tracks or genres your group used for testing.
We had music specifically recorded that showed off each criteria we wanted to demonstrate. Some jazz, some classical, some classic rock etc. Each tester was educated in what to listen for on each track. Senn HD 800 headphones were used. The only power tubes used were Tung Sol 5998’s and I built every cable used.
Aug 14, 2023 at 12:39 PM Post #9,169 of 10,669
RCA 5692 red bottom is a fun tube.
Aug 14, 2023 at 12:51 PM Post #9,170 of 10,669
Very nice. RCA used to be big in my area. Largest color television plant in the world was here. We tested a couple 6SN7’s that a friends grandfather had designed. We knew values of most tubes but those were one of a kind and in a sense priceless. I was scared to death handling them.🤪
Aug 14, 2023 at 1:22 PM Post #9,172 of 10,669
So far from what I tested my top 3 in no particular order:
  1. GEC / Osram L63
  2. Mullard ECC33
  3. National Union RP 6F8G
Tested in my EC Balancing Act with Utopia OG. My amp leans neutral and fast which makes driver tube selection trickier than usual.
I use the Utopia OG myself, we used four of the new versions when we tested DACS some months back. I have yet to buy my dream DAC but I know which one I want.
Aug 14, 2023 at 1:35 PM Post #9,173 of 10,669
  1. GEC / Osram L63
  2. Mullard ECC33
Those are some obscure ones but intriguing to me. Is the Mullard ECC83 a drop in replacement for 6SN7?
Aug 14, 2023 at 1:56 PM Post #9,175 of 10,669
I read that it is a drop in replacement for a 12AX7, might need an ECC83 / 6SN7 adapter
Aug 14, 2023 at 3:04 PM Post #9,176 of 10,669
I dunno what else to try next, Sylvania short bottle 6SN7W maybe? 😂
Frankie 7N7. Same construction as 6SN7W, but deconstructed pricing.
A better 6SN7 might be an early ECC40, foil getter from Eindhoven. Later iterations are less enamouring.
Concur regarding 1578s - enjoy the 50s versions. From the 60s onward they get more V-shaped and harsher.
Have you tried a Brimar CV1988? They used to be the old hotness after the TS RP hotness wore off and before the 1578 hotness began. 🤣
Aug 14, 2023 at 3:14 PM Post #9,177 of 10,669
:beerchug:
When talking 7N7's there were also the single triode 7A4's, we included those and 6J5's as so 6sn7 equivalents. I look at our test scores as I would look at the ratings on a fine bottle of wine. 100 being a perfect score, when you find a tube that a large group of people say is in the high nineties, you have something spectacular. :ksc75smile: Especially when you give it a similar score yourself. Fortunately a lot of my tube gear uses 6sn7's so I did not mind spending the time. Looking at my main system, I just counted 34 tubes in play, with another twelve in gear in my shop.
