JKDJedi
It's a great pairing Sennfan.Damn, how is that Western Electric 421A+6F8G/VT-99 (Sylvania?) pairing?
So a 1953 Foton might be a good buy.. ?That particular tube is a 1965. The '60's are nice sounding tubes, but bettered by the '50's. Not huge differences between the '51 - '56 rib plates and the '57 - '59 smooth plates, but I think the ribbed versions are still a bit better. Note that the pin soldering on these can be questionable, whether it was poor workmanship or poor quality solder that has degraded over time. On the plus side if you bought them from Upscale you should get a properly working tube out of the box.
That is a ‘65 Foton basing from the picture. You can get them for cheap from former Soviet Republics. Great price/performance. The ‘57 and below sounds nicer to my ears but is getting hard to find especially from a reputable seller.Have these on their way, a bit of an impulse purchase from Upscale Audio to use in my Feliks Elise. All Upscale notes is that they are early Russian, found in a cave in Brazil, intriguing but not very specific. Can anyone help me ID their make / year of production?
Good eyes, @bcowen, I missed that entirely. I appreciate it! And thanks @cebuboy for confirming. They should arrive by tomorrow and I'm excite to test them out!That particular tube is a 1965. The '60's are nice sounding tubes, but bettered by the '50's. Not huge differences between the '51 - '56 rib plates and the '57 - '59 smooth plates, but I think the ribbed versions are still a bit better. Note that the pin soldering on these can be questionable, whether it was poor workmanship or poor quality solder that has degraded over time. On the plus side if you bought them from Upscale you should get a properly working tube out of the box.
Thinking it's plain vanilla, I scrape mine with pocket knife.A question regarding tube cleansing: is there a coating on the tube pins, or is it just plain vanilla zinc (or steel?) ?
If there is a coating, then using sandpaper or blade to clean pins could be problematic.
That's where the Deoxit comes in, adds a coatingI think so too, but not 100% sure about it.
It's softer than the blade, and can be scraped off easily, so I don't think it's steel, mostly likely it's plain vanilla zinc.
The bottle I posted just does the coating, cleaning with alcohol like the others posted (I use a q tip)and scraping with knife works for me for cleaning duties.It is a really good idea!
Does the glass bottle one you quoted earlier has a coating component other than de-oxidation and cleansing?
Why is adding a coating a good idea...does it improve conductivity / some other sonic virtue?That's where the Deoxit comes in, adds a coating
According to Deoxit.........YES!Why is adding a coating a good idea...does it improve conductivity / some other sonic virtue?
Hmmmm, these arrived from Upscale Audio. I'm evaluating their sound and thus far pleased. The caveat is that one of the tube's filaments glows brightly and the other very dimly, a very visible difference. I swapped sockets and it is clearly the tube, not the socket. I did order them in driver / buffer grade as I'm using them as drivers, so didn't expect a perfect match, but the difference visually is striking, not sure what to make of it. Sonically, I do not notice any channel volume imbalance nor extraneous noise from either tube, but wondering if this is "normal" or warrants asking for an exchange.Have these on their way, a bit of an impulse purchase from Upscale Audio to use in my Feliks Elise. All Upscale notes is that they are early Russian, found in a cave in Brazil, intriguing but not very specific. Can anyone help me ID their make / year of production?
