There are 4 or 5 methods you can try...start with the easiest for you.I'm going to flip them. I'm guessing issue is one specific driver tube. Constant low static noise.
1. Pull out the tube and insert again...swap side if applicable
2. Clean the pins on tube plus the pins on socket
3. Tap repeatedly the side of the tube on the table very lightly and roll as you do, do it when the tube is still hot or warm. Lastly, holding it upright and tap lightly the base of the tube on the table. Note...tap lightly NOT knock or bang. It is advisable to use a multimeter to check for short after this operation before inserting it back onto the amp.
4. Heat the tip of every pin of the tube with a soldering iron for about 10 seconds, remember to use flux on the tips.
5. Do the same as above but make it to 30 seconds or more, and pray you didnt burn anything.
Last resort if all failed...burn the tube on the amp, or better on a DAC or preamp for hours or overnight.
Good luck!!!
