ColSaulTigh
Liquid (not the gel) super glue.
Acetone(finger nail polish remover) it must ‘reactivate’ the original cement used. It works most of the time. I use a small paint brush, dip it in the acetone and run the brush carefully along the edge of the base so it flows in. Then either rubber band it tight or just hold it firmly in your hand for as long as you can stand it.Hey, it is probably in this thread or on this forum somewhere, but don't have lots of time to search, so apologies if this is repeated question. But does anyone know how to easily "fix" or re-glue a loose base on a tube? You know, the plastic part at the bottom - a lot of these older tubes will function fine, but the base will be a bit loose, and I was hoping there might be a simple way to go about getting that glued back down again.
I had good results with a liquid crazy glue that I brushed on sparingly between the socket and the glass. Somebody said the crazy glue is conductive but I never had any problems. Once brushed on, hold in place for a minute and then let it dry 12-24 hours standing up. If necessary, secure with rubber bands etc.Acetone(finger nail polish remover) it must ‘reactivate’ the original cement used. It works most of the time. I use a small paint brush, dip it in the acetone and run the brush carefully along the edge of the base so it flows in. Then either rubber band it tight or just hold it firmly in your hand for as long as you can stand it.
+1 no messAcetone(finger nail polish remover) it must ‘reactivate’ the original cement used. It works most of the time. I use a small paint brush, dip it in the acetone and run the brush carefully along the edge of the base so it flows in. Then either rubber band it tight or just hold it firmly in your hand for as long as you can stand it.
I will let others chime in on their experiences but please correct me if I have misunderstood you, I think you are talking about tube base or just base and not socket.I have a noob question.
Socket and pin choice, which effect do they have?
Let's say a manufacturer has a 6SN7 tube and then makes a Version of it with ceramik socket and Gold Pins, will there be any difference to other sockets and Pins?
Base, or in my noob words "part of the tube not of the amp"I will let others chime in on their experiences but please correct me if I have misunderstood you, I think you are talking about tube base or just base and not socket.
This is a base...
These are sockets...
IMHO, I think no one really cares whether the base is made of ceramic, Bakelite or PTFE / Teflon, most people only care whether the tube sounds good or not...Base, or in my noob words "part of the tube not of the amp"
The only thing I have come across regarding base material, is in regards to some materials may be more efficient at preventing the heat from the tube transferring to the amp. It’s possibly of benefit, but the electronic components under the top plate are going to be warm anyway.Base, or in my noob words "part of the tube not of the amp"
As mentioned, it does not seem to make much of a difference with different materials.True, I did notice that my metal base 6080s result in a hotter amp top plate than the plastic base equivalents like 5998, 421A or 6AS7G. Even though those are supposed to draw more power?
The base doesn’t make any different for audio. You’ll see some references to “low loss” micinol bases (I think). Those apparently could help in certain applications. I’m guessing things like use in measuring equipment and maybe RF work were more sensitive to something that audio isn’t. The only upside to gold pins is that they don’t corrode.I have a noob question.
Any reason why silver could not be used (have been used) for tube pins? Highest conductivity, resistance to corrosion.![]()
