Today I am modifying an OTL amp for a gentleman from Chicago. This is a prototype and while most of the measurements were decent it sounded pretty lifeless when I got it. I will not go into circuitry changes but he was wanting more bass. So after my adjustments I put in a 52 Foton and various power tubes. The gain of the 5998 helped drastically, and one power tube I own really beefed up the bass and mids.
For disclosure, I have never been a fan of the GE 6SN7 (side getters). That being said, I tried (these tubes) very early on when I first received a tube amp, and I did not know much about pairing them or synergy with power tubes. I would say from what I remember, the GE 6SN7 was also a mid-forward tube good treble, but it did get fatiguing. The bass for me was alot bloated, uncontrolled, really a mess in that end - my biggest point of contention with this tube. But that's just my own experience and 2 cents. Maybe with a much better amp, or better pairing/synergy, it shines in other situations. Just didn't with me in this case.
Let's just say it is a more valuable amp because of the changes I made and parts I added. I did end up sending a Foton and a GE 5998A with the amp to help as well but that was only $75 in tubes. The capacitors I swapped were more than that.
I included a GE 5998A to help a customer but I can get more, and I know if there are issues when I buy them, resoldering the pins fixed two more in my possession.
As far as Crack mods I kept the original power transformer, and IEC socket. On my own Crack I used Dual Alps black widow pots, a copper top plate, a quartered oak cabinet, VU meters, a different 1/4 inch Jack etc. I did keep the BH badge.
I have front and back copper plates and added a pre-amp out circuit. No Jack’s or pot on the top plate.
I am running a 1961 Melz 1578 in one of my amps, best tube I have heard for ages. No flaws across the audio spectrum, great separation, no background noise. My favorite had been a 1958 Melz with solid plates but all the same features of a 1578 otherwise. This tube ranks with that one and so close in sound I doubt it will change anything in a tube challenge I am involved with. Only tubes of vastly different construction are allowed within the same brand.
This would be it, the 56 and 58 solid plates I own are identical IMHO. I have had seven friends grade the 1958 for our tube challenge and nothing beats it so far, no other tube or combination of single triode tubes or other equivalents come close. I will get this tube graded as well but in A/B tests in identical amps I cannot hear any difference. As far as power tubes, if you pair one of these with a TS 5998 or a Chatham bottom getter 6AS7G the outcome is as good as it gets for me.
To @HTSkywalker : the chances of finding one of these particular Melz tubes is between none and zero. @Paladin79 already has Russian mafia friends (with baseball bats in hand) pillaging and pilfering though every domicile in the entire country looking for the last ones in existence. I think he even has insiders rummaging through Putin's personal stash after bribing coaxing some top brass at the Kremlin. So in other words, just give up.
