mordy
- Aug 8, 2010
There is a Russian tube GU50 (basically a copy of the Telefunken LS50) that has four getters and uses both Barium and Zirconium getters. Zirconium is supposed to work better than Barium - another tube that uses Zirconium getters is the C3g tube. My guess is that it helps to get better vacuum.I agree with you. If two tubes with different getters sound different, it isn't going to be because of the getter, it's because one is older than the other and may have been made on different equipment and have other construction differences that explain the sonic changes. Getters are just one part of the puzzle in figuring out when tubes were made.
One exception I would note is that in the case of tubes whose *quantity* of getters varies I would suspect that more = better. Such as a 5998 tube where you will see ones that have only a top getter and some that have both a top and a side getter, I would be willing to bet the tube with the triple getter setup may have a longer usable lifespan. Possibly the reason for this variation was that some of these tubes were meant to be "long life" variants, but that's just me theory crafting..... I haven't read anything to confirm that.
https://www.jacmusic.com/techcorner/ARTICLES/English/Portraits/GM50/index-GM50-Portraits.html
Telefunken LS50:
GU50:
