jasonb
- Sep 14, 2010
Looks like two different usage profiles (perhaps different IEMs, volume leves?). Your first two draw downs would indicate ~460 minutes (simply apply straight edge to the lines on the chart). The last draw down was much more gradual - 1/3 drain in 300 minutes, so ~900 minutes for full draw down.
Mine isn't draining at a linear rate.
This is performance at 1v, volume is between -30 to -40, using LDAC at 24/96 990kbps, and using the PEQ. I'm assuming the PEQ must consume some battery since it doesn't look like I'm going to the the 13.85 hours they claim with my current settings. I'm thinking I'm going to get 11, maybe 11 and a half hours at this rate.
I'm also curious why it didn't charge to 100%.
2 hours later:
