cloud_c
- Feb 19, 2007
On a bass note, I've been listening to organ music for the last couple hours in audio bliss.
I personally have 20Hz at +16db and the Z1R is handling it quite well with bass detail.
In particular, on the CD Johann Sebastian Bach; E. Power Biggs, tracks 1 and 3 stood out as great.
Track 1 has a wonderful play on notes across the range from sub-bass to treble.
To my ears, the volume of the notes matches the graphic analyzer that I have going at the same time.
Track 3 has a continuous sub bass note that plays for 1minute and 6 seconds(roughly).
It is a telling test of the bass capacity of any earphone.
By comparison on the SZ2K, I have 20Hz up 12db... hmm I thought it was more, but I guess that is because the whole fr range is a mess and 864Hz is -9db.
This would mean that if one can accept the fr of a stock SZ2K that the sub bass would have more presence/power, but I can't accept any headphone at stock performance.
Clearly the Z1R is not the king of sub bass, but it is good.
I don't have a TH900 to compare to, but the fr range didn't appeal.
It is quite possible that the TH900 has a stronger sub-bass presence stock.
If one compares the fr graphs it is easy to see that the TH900 has a big bass peak at 40Hz.
The thing is, it drops off 3db by 20Hz whereas the Z1R drops 1Hz from its peak at 50Hz down to 20Hz.
This doesn't sound like a lot, but if you look at the curve it is easy to see that the Z1R is practically a straight line from 50 to 20 whereas the TH900mk2 is a curve down that is only accelerating downward at 20Hz.
That is a big deal to me. The SZ2K is flat in the sub bass too and down many db more than it should be.
Personally I find it too bad that the Z1R drops 3db in its response from 100 to 70Hz, but oh well, whatever, its sub-bass ability details that I'm looking for.
With literally two times the surface area of a 50mm driver, it is no surprise that the Z1R can hit the low notes.
Now if I could get them permanently tuned with a +16db boost at 20Hz with a 12db slope I would be in heaven from any device, not just my computer.
