dnnaudio
- Jun 5, 2006
Stock cable. The Hugo is quite neutral, some even call it slightly bright, but definitely not warm nor rolled off highs. It should have been a synergistic match for the Z1R. I also think there is some variability in terms on what I feel as dark as against what others may feel. I am a primarily two channel guy and my speakers are Harbeth, Spendor and Dynaudio. These speakers to me are very slightly dark (as opposed to speakers like Focal and B&W), however in contrast the Z1R w/ stock cable to me is even darker to the point where the natural sharpness and bite in notes is blunted a bit.
What cables were you using out of the question? The standard stock cable? The reason I'm asking is because a few weeks back, I wrote the same to a fellow Z1R colleague that I felt it was a little dark with a treble spike off my WM1Z and comparing against the Elear back then.
This past weekend at the Fujiya show, I was at the tried out these other cables off their balanced amp and now that you've talked about a dark signature, I'm thinking back I didn't get that feeling with the Z1R. It prompts me to want to try more cable variety with the Z1R to see if that darkness is due to standard/stock cables. Naturally I'm wary as the cables were almost to the cost of the Z1Rs themselves. But if it proves to be the cable, then at least in my eyes, it demonstrates the Z1R is somewhat noticeably scalable, and it's not just pure grunt power that it needs to get the most out of it, but maybe more clean/consistent power drive. Again this is almost pure speculation with a brief 10 min actual listen.
