Fegefeuer
- Mar 17, 2011
CMSS-3D treble can be horrible with a few headphones. I wish we'd get a proper OpenAL implementation for Z cards.
Quick Question and maybe get a good detailed answer lol.
I bought an Asus Xonar DG, just because I really wanted to test out Dolby Headphone and it was cheap too (16 bucks after rebate).
Anyways, I was wondering, what does the Mixer tab do? I saw a youtube video saying that you should drop it to about 50 percent so the peaks dont go over 0dB. What is he really talking about? Says that if the peaks go over 0dB, you will get distortion and more if it goes up to 20+dB.
Not sure what he says is true or correct.
Thank you
I know what clipping is but how will I know when it will happen or how can i set up the mixer in the Asus Xonar control panel? I did crank it up to 100 and noticed some clipping thus i turned it down again. But Im not sure if the default 76% is good enough or should I lower it?
Wanted to bump this with a question I had. I am about to play an order for an external dac/amp with headphones. It will be used for 90% gaming, but I am trying to decide if I should get an SBZ for virtual surround. Or just play games in high quality stereo.
If I would just to use a dac/amp setup and 2.0 stereo only, do any games ever have their own HRTF audio for headphones? I noticed some games give you an option to choose surround or headphones. I am curious if the game sees your selecting headphones, does it use it's own virtual surround?
Or does every games audio fall under one of the API's mentioned in the OP?
Thank you
What do you guys think about this new sound card PowerColor is releasing?
http://www.techpowerup.com/213055/powercolor-devil-hdx-sound-card-detailed.html
I thought they only focused on Graphic Cards but guess they are trying to get at Audio as well...
Hello everyone.
I'm basically looking for some advice on a good audiophile sound setup for PC. I'm just about to build my 1st gaming PC and don't know how the sound setups work, I've always been a console gamer in the past.
My current setup for console is astro mixamp pro as my DAC then schiit vali for my tube amp then Akg q701 for my headphones. So I'm looking for a good sound setup for PC now.
I also want to switch from Dolby surround sound to sbx true surround sound so looking at sound blaster products. Can I get a few opinions from use guys please ?
Games I'll be playing are cs go arma3 battlefield and maybe some cod also ordered a msi gaming 5 mobo but not sure if the audio on that will be very good.
Sound Blaster Z. Probably the best and cheapest option out there for PC unless you want to go Sound Blaster X7 and ditch the Astro Mix amp all together. X7 can be used both for consoles and PC.
As for your motherboard, it seems to have better quality components than a regular motherboard but the Sound Blaster Cinema 2 seems to be more software oriented than hardware but not sure to be honest. It could work but the quality wont be the same as a Sound Blaster Z.
Also, whats your budget?
Budget was £1500 for everything but I'm at £1950 already lol so don't want to buy an x7 unless it's way better than a sbz. So best option is sbz > schiit vali > q701 ? That would be ideal since I already have the vali and q701s
well the X7 is better than the SB Z in terms of quality of sound, not by a huge margin but a more noticeable margin.
But you should be good with an SB Z and Vali though I should say that in this case, I wouldnt recommend double amping. You should buy an optical Modi so you can send the SB X signal through the SB Z optical out into the Modi Optical in, which then is connected to the Vali and your headphones. By doing this, you will get a better and cleaner sound while still getting the SB X surround through your headphones
Ok I think I get it so sbz >modi optical> schiit vali>q701 and I'm all set ?
Also if I was to go with the x7 is that all I would need or would I still need the sbz ?
