pietcux
PCIE 1x can be inserted into any PCIE 16x slot, so the soundcard could also run underneath the graphics card.
Only my front USB slots are hooked up but I don't use them. Everything plugged into the back. I have a coolermaster haf x case. From what I gather its basically EMI from gpu/CPU/mouse or some combination of. My sound card is in the pci express slot sandwiched between my CPU and gpu so maybe if I move it to another free slot but I think the only free slot is right below the gpu since it takes up 2 slots on its own. I could also move the gpu down a slot and see if that helps.
Hey guys long time lurker first time poster,
I have a few questions -
Recently I have purchased Annies, which will primarily used with my computer (gaming first and foremost and then music/anime/movies) and maybe possibly for console use down the track.
After reading through majority thread I have become a little confused.
Currently from what I understand I need to purchase a sound card/ external equivalent to produce virtual surround sound and also amp.
I was planning to purchase o2/odac combination and a Asus Xonar Essence STX for Dolby Headphone. My main problem is how to connect these all together and whether I should consider another option to output the virtual surround sound to the headphones.
Thank you very much.
I don't see why you're even bothering with the ODAC if you're buying a sound card like the Xonar Essence STX.
Just get the Objective2, if the STX's built-in amp isn't good enough for you or the K702 65th.
