Mine was about 1/2 inch with a bite block. So far things are good.
The JH16 Pro Impressions Thread
- Thread starter longbowbbs
Tamz
- Jun 14, 2008
yup generally bit block is the way to go when making ear impression.
essential-oils
Previously known as jlesnick
- Dec 21, 2009
Which dac/amps have you guys had the best luck with (with the jh16 w/fp)?
chengsta
- Mar 30, 2013
My audiologist was arrogant, and it seems like most are, by the look of things. He told me I didn't need a bite block, and that jh audio was just being paranoid. I left my jaw loose though.
It all turned out fine, no fit issues but I didn't like his attitude.
Girls Generation
- Feb 7, 2010
My audiologist who took my impressions was an artist who owned CIEMs himself, who also experienced the lack of skill of many audiologists/technicians who did his molds. So now he practices and makes sure his clients get a perfect fit the first time.
Bite block is so that your jaws don't move.
As long as your audiologist knew what he was doing, it should be fine. Some inexperienced audiologists don't pack the silicone tightly enough and it makes for a looser fit.
Any kind of health practitioner who is arrogant should have their license taken away, imho...
Deviltooth
- Mar 1, 2012
I think the best advice is to follow the directions of the company making your CIEMS. Open mouth with a bite block is usually what's advised for acylic based CIEMS. Closed mouth and smaller bite blocks are often associated with silicone CIEMs.
Each individual's ear canals are different and the amount and type of deformation with jaw movement can vary.
flaco
- May 31, 2013
Exactly my opinion!
I had luck with my audiologist. He told me that he was a speaker engineer before he became a audiologist. He said that if I put the volume always to the max I will be back as a customer in several years but not for Custom-IEM...
I am going to order tomorrow ! I am facing problems with my credit card at the moment.
My Audiologist works with a lot of bands. He has them sing during the fitting just like they would be doing on stage. Guess it works. I tried not to move, lol!
edyeded
- Jul 3, 2013
Guys, need help choosing a cable for my jh16s.
Filtered down to:
1. Toxic cable - £155
2. HPL Audio - £130
Toxic has a wait period of 10 weeks...at least!! HPL are like 3 weeks.
Any input from guys that have experience with these cables would be great!!
Filtered down to:
2. HPL Audio - £130
chicagojammer
- Jun 5, 2009
I posted a separate thread for this question but should have just asked here...I just got my JH16's this weekend, I love them but notice a annoying suction/loud popping sound on my right ear. The sound does not really degrade but it's pretty common when I am moving and distracting. I notice when i look up with my mouth closed the same thing happens. My left canal tip seeps to be longer and I don't really have this issue though it does move a little. Do you think I should extend the canal tips or maybe just get a wider aperture so the seal is better. The popping does not happen when I put those comply strips around the aperture area so I am thinking that's what I should do.
Toxic's are worth the wait....IMO they are the very best cables you can buy....However, they do require patience. Sometimes quite a bit of patience.
Filtered down to:
2. HPL Audio - £130
Girls Generation
- Feb 7, 2010
I have HPL audio cables and they're amazing (I've also tried Toxic, and MANY other cables). TOTL quality with genuine OCC wires. Toxic is good too but 10 weeks is two and a half months. I'm also aware it's much longer than 10 weeks. However, 3 weeks is 3 weeks. Save some money and treat yourself to a nice dinner.
I don't think I can ever wait over 2 months for a cable, I had a hard time waiting 4 weeks for the JH16...
Make sure you buy from hplaudio.com.
Being a supremus, you should know better than to post things like this.
Filtered down to:
2. HPL Audio - £130
Girls Generation
- Feb 7, 2010
What you should do is contact JH and describe this issue to them, and send it back.
I do love my Toxic's....I have a set coming in for the HD800's too.....
