DKJones96
- Nov 25, 2008
I don't know that I'd worry too much about those vias. The type of soldering job that an SMD chip like that takes shouldn't have enough solder on there to bridge with anyways.
Originally Posted by DKJones96 /img/forum/go_quote.gif If you want the cleanest sound possible you want the digital signal to be carried and decoded as close to the amp as you can get it. Stay digital as far down the line as you can. |
Originally Posted by mugdecoffee /img/forum/go_quote.gif Maybe true but in this case we'd just be getting rid of the USB cable which could only help. My gripe is that if I'm using the bantam DAC in the car, there's a USB cable from my computer to the DAC, a cable from the DAC to my mini3, and then the headphone cable. It really becomes a mess quite easily. |
If you integrate the bantam or this new grub dac with the Carrie amp, its not a problem. But while the topic of usb connections is up, it'd be nice to have support for a male connector. |
Originally Posted by mugdecoffee /img/forum/go_quote.gif If you wanted to use the actual mini3 amp because you already have one or because you want to use the amp with other sources it'd be nice. You'd still have a cable to the mini3 but you could eliminate one more cable you'd have to carry and hook up. It may be a little fragile but not anymore so than a flash drive. Mostly it'd just be nice as an option especially it it would only take adding a few pads to the board. What I'm picturing is something like: USB Sound Card with Virtual 7.1CH (C-Media Chipset) - China usb sound card, usb sound adpter, usb 7.1CH sound card in Sound Card It just seems silly to me to require two cables to connect such a small device. |
Originally Posted by tomb /img/forum/go_quote.gif This is DIY. There's nothing that says you can't use a male USB plug instead of a female USB socket. Me? I'd rather have the cable anyday - I've snapped off enough flash drives to teach me the value of a cable. Once you start going that route, you have to consider the stresses of a mechanical connection with the cantilevered weight of the device hanging off the end, etc. It's not a pretty picture when the USB connector on the other end is directly connected to your laptop's motherboard. Ouch! |
Originally Posted by tomb /img/forum/go_quote.gif Yep. There's also this adapter that will work with the Bantam - USB Adaptor A M To B F USB Port Converter | Distributed By MCM | UA-002 (UA002) I haven't found one yet for a Mini-USB, but there's got be one out there. |
Originally Posted by Billyk /img/forum/go_quote.gif Yes, shouldn't that "innie" be an "outie"? |
