This is fine up to a point, but there is a critical problem with optical, which is that at some point the optical signal has to be converted back to an electronic signal to produce audio. This conversion process is inherently "noisy"generates unwanted RFI, so if you connect supply your data optically directly into the Streamer, you then have no control over how the electronics in the streamer makes this conversion of light back to electrons. In my experience you can achieve better results or a better sounding streaming set up by cleaning up the signal in electronic form before it reaches the streamer. We have lots of customers who come to using fibre either in this way or more commonly (as not many streamers have an optical network connection) using it like this:
Router or switch > ethernet cable > 1st fibre convertor - fibre cable > 2nd fibre convertor > ethernet cable > streamer.
The problem here is that the Fibre convertors are active so while they act as a buffer preventing noise passing through, they create and emit noise of their own generated converting back to ethernet and of course picked up from their power supply.
All of this said, fibre convertors offer a cheapish improvement over running your streamer straight out of the router, but its not a cure-all for removing unwanted noise.
Disclaimer: i am an evil maker and seller of snake oil
