bfreedma, with your over 30yrs of extensive Ethernet experience, can you please explain to me why these three cables sound completely different from one another in my headphone system if all they are doing is transferring nothing but 1’s and 0’s. The yellow one is the stock cable that came with my ROON Nucleus Rev B music server. The black cable was made by Network Acoustics. And the red Ethernet cable is from L-Com and it costs $20.
I assume that you have had friends help you blind test these? As in, you had your friends randomly switch those ethernet cables (or not) without you seeing it happen, and then you were able to reliably determine which cable was being used after each "cable switch"? If so, please do not change anything in your system, because it is unique and various electronics companies would pay you millions of dollars just for the rights to examine and test it. In fact, I'll fly to your place myself, to witness this ... you could be the modern day Bernadette Soubirous!
The question that needs to be answered is this: do they sound different or do you just think they sound different? This can be tested, you know.
Exactly.
Within your knowledge of the 802 specs is there anything concerning maximum allowable timing errors between data packets ?
No, nothing in 802 that I'm aware of. Linux (which most devices seem to be running these days) has some hard-coded 5000ms time-outs on some TCP/IP retries, so
in theory, with super high packet loss, you could hear an interruption after 5 seconds (plus the period of time represented by the buffer on the audio).
TLDR: Ethernet is almost never effected by jitter as it is asynchronous- buffering allows for problematic packets to be resent and replaced in correct sequence before the audio device needs the data.
^ this
Not ignoring it, just asking what if any specified timing tolerances are involved “less than 1us … less than 4us “ ?
A little off topic but would you say Wireless could be better, worse or just the same as Ethernet for digital audio ?
The issue with wireless is that there are many devices (and other things) polluting that spectrum, so your packet loss rate will often be much higher. In the real world, this doesn't usually have any noticeable impact, since the packets are resent as necessary until everything gets through correctly, but ask an engineer, and they'll tell you to wire it.
I've heard the same counter for years, starting with amps, then speaker cables and interconnects, then digital cables, now network gear. My current streamer and DAC are made by exaSound and are technically proficient and highly transparent. The transparency allows me to hear clear differences when I swap ethernet cables or upgrade a power supply. (I always clear the buffer after a change and before continuing).
(I swear I've heard this before, somewhere.)
Blind testing of the type you refer to is known to be unreliable.
People do not need to satisfy anyone other than themselves. This is the big mistake people make when jumping all over these types of threads with their repetitive 'it makes no difference and you have to prove it does' posts. People are under no obligation to prove anything - they are simply trying to discuss their subjective findings in this area, such discussion usually being drowned out by a few persistent posters. This seems to happen on all forums, some being worse than others.
The vast majority of people who try this sort of thing believe that they hear a difference and it is often significant. You can either take the position that every single one of them is wrong and you, despite not having tried it, are right, which is somewhat arrogant, or you can take the view that perhaps there is something in it and it might be worth investigating, as I did despite my strong bias and belief that it would not make any difference. I found my belief to be incorrect. I don't need graphs or a scientific study to know that I hear a difference.
Blind testing of the type being described
is reliable. That is why you do not like it.
However, you are correct about this: "
People do not need to satisfy anyone other than themselves." I totally agree! My cables are made from special materials, by artisans, by hand, and I pay way (
way!) too much money for them. They are beautiful, and therefore they sound awesome, to me.
Is it placebo effect? 100% you better believe it is! That's why I pay so much for those beautiful cables --
I gladly, 100% rely on placebo effect! And I am not at all ashamed to admit it. Why should I suffer through my relatively horrible sounding music with ugly cables, when I can spend gobs of my hard-earned money on beautiful cables, and personally perceive that it sounds better? Why would
anyone not spend lots of money on cables with this wonderful, magical property? (And as a bonus, they look great!)
So you are correct: "
The vast majority of people who try this sort of thing believe that they hear a difference and it is often significant." And that is fine,
as long as you are not making false claims to sell those products.
In other words, the placebo benefit is for us, the consumer. If we want to lie to ourselves in order to increase our pleasure of listening to music, then more power to us! But when a snake-oil seller is lying, that is immoral, unethical, and in most places, illegal.
So, for example, there is absolutely nothing wrong with this user (bluenight) enjoying the placebo benefits from his "supa cat 8" purchase, and in fact I applaud the brilliant choice of spending his money on something that increases his joy of listening ....
I use supa cat 8 all the way. Im happy with them, smoother and darker more detailed more resolutuon, more musical, better timber, more body compared to generic cat5 i had.
However, I do think that there is something wrong with making technical claims about the differences (since there are none).
But then again, maybe that "Supra CAT8 cable" isn't all that it's cracked up to be:
I agree with your description of how the Supra CAT8 cable sounds. My concern is how it handles transients. The initial whack of the transient is slightly damped or softened, which removes some excitement from the music. I am only able to detect this characteristic in comparison to my CD transport and my computer audio system using the other two ethernet cables. The Supra cable is otherwise exemplary, but unfortunately that one flaw makes it unsuited to my system and preferences. Note, these differences are subtle, only evident through extended listening.
We have come full circle.
Despite there being absolutely zero
actual difference in the audio between the $.99 monoprice cable, the $1.99 Amazon Basics cable, the $.37 Alibaba cable, the black one that came for free with some other random device, the $50 Supra CAT8, and the $1000.00 snake oil cable sold by some guy on this thread, here we have the careful and nuanced critique of that $50 cable.
This is the equivalent of comparing the audio coming out of your headphones when you're streaming TIDAL FLAC, and saying that you notice differences in the audio quality between your COMCAST cable modem connection and your Verizon FIOS connection. For example, based on what I've learned in this thread, I could pseudo-sincerely posit that:
The FIOS connection has a more antiseptic quality to it, probably caused by the photons in the fibre-optic connection being sterile from the use of non-organic compounds; it's a good reason to avoid fiber, unless you're using it for professional, clean-room audio mixing. The COMCAST connection, on the other hand, is far warmer, thanks in no small part to the heaviness of the RG6 coaxial wire, with its custom Mylar sheath, which massages the audio signal and adds significant depth and unbelievable stage width to the listening experience. Note, these differences are subtle, only evident through extended listening.
TLDR:
you should -- if at all possible -- take advantage of, and enjoy the placebo effect. But speading misleading information is not OK. And profiting from the spread of purposefully misleading information is immoral, unethical, and in most places, illegal.
