You have a fundamental misunderstanding about how Ethernet and packetized data functions. And yes, it is science/engineering - who do you think developed the standards and associated technology. How do you think so many diverse devices communicate reliably over Ethernet? Magic?
Again, with error correction and galvanization (eliminates interference and noise), what else could impact an Ethernet connection? You keep saying there is something - what is it?
Explain how audio data is different than financial data transmitted via Ethernet - provide some details as to how any device in the chain identifies the difference between packets containing audio data and any other type of data. Hint - there isn't any difference.
All that said, you seem to believe the 802 standard is incomplete/incorrect. Tell you what: you write it up and I will get you a slot in front of the right 802 subcommittee to present your findings. If it's the 802 subcommittee I'm a member of, I'll be there for the presentation as well.
Bottom line - my position is based on the 802 standards and trillions of packets successfully delivered, error checked, error corrected, and processed daily. Your position is based on parroting what a bunch of "high end" cable vendors use as marketing materials, including some on this very thread. Congratulations on perfectly encapsulating 2021, where science and knowledge is discounted and the subjective opinions of those with a profit motive take precedence.
