smeggy
Member of the Trade: ThunderpantsTP1
- Feb 9, 2004
I have a 7Mk2, can I just strip it out and rebuild in a bigger case with new transfos as a direct replacement without changing anything else?
Originally Posted by pidesd /img/forum/go_quote.gif what lundahl trafos are you using? i d like to put these in my srd-6 (well not actually inside... also can you describe how connect them? |
Originally Posted by smeggy /img/forum/go_quote.gif I have a 7Mk2, can I just strip it out and rebuild in a bigger case with new transfos as a direct replacement without changing anything else? |
Originally Posted by pidesd /img/forum/go_quote.gif spritzer, i d really be interested in buying one of your pcb's if you have some spare and if you want to. of course they have to pass the test first. i m not sure about the circuit, but if it is similar to the mk2 one shown earlier in this thread, then i guess i just have to tap the the supply line a bit earlier when it s 230v if i want to feed normal bias phones? |
Originally Posted by spritzer /img/forum/go_quote.gif A transformer will never match a properly designed direct drive amp. There are a number of factors that contribute to this but it's largely due to optimizing the amp for the given task. A speaker amp, driving an odd load through a transformer will always be at a disadvantage. |
Originally Posted by spritzer /img/forum/go_quote.gif Yup but you might as well sell it and start off fresh. I got the upgraded SRD-7 Pro bias PCB's yesterday but have to test them to see if all is a-ok. If all is well then I can build one for you. I even added some extra mounting holes to make them easier to use in a non SRD7 configuration. |
Originally Posted by smeggy /img/forum/go_quote.gif can it run pro and normal bias as I use both? Great work btw, very cool indeed! |
Originally Posted by krmathis /img/forum/go_quote.gif Would not be surprised if he use the same transformers as in this project. the STAX Transformer |
Originally Posted by AudioCats /img/forum/go_quote.gif Mine are LL1627, similar turn ratio, larger and heavier. |
