Pingupenguins
Member of the Trade: BTG Audio / Q Audio
a.k.a. solder sucker, [de]solder[ing] pump
ardgedee, add USB plugs when building your own: on the male type A connector, when looking at the pins and they are facing upward, the pinout is GND, DATA+, DATA-, +5VDC. On the male type B connector which is what usually goes into a desktop DAC, when looking at the plug with the longer, flatter side towards the bottom, the first two pins from left to right at the top are +5VDC and DATA-, the the other two on the bottom from left to right are GND and DATA+.
Whoops. I meant Solder fume extractor, but a solder vacuum can be used too. I don't call solder vacuums, suckers because they can be mixed up with braid in my experience.
A USB type B pin out would be nice too!
