H20Fidelity
- Feb 11, 2012
OK!! battery is showing signs of life!
Having plugged into a 2a charger for a further two hours, the low and medium led is now flashing. If I unplug the unit, the led indicators medium charge while is a improvement from not even turning on!
Like mentioned use a 2A charger, also many people over look this. The cable you use is important as well. Some cheap USB cables will limit the amount of amps to the device charging.
Look on Australian eBay and pick a Remax USB cable for about $7, they're excellent sheathed USB cables promised to deliver the correct current.
