tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
- Sep 27, 2001
As a generalization, yes, that's true. However, some common-ground amps are better than others.
I'm not that dude but I can do the calculation. The phones are 74dB/mW, so they need about 41mW to reach 90dB, the loudest you should listen. Into 120 ohms, P=IIR says you need 18mA. Ohm's law says you get that at 2.2Vrms. 18mA at 2.2V is beyond the abilties some portable amps, but most anything else should be able to achieve these specs.
Now, if you wish to listen at over 90dB SPL, the numbers start getting insane. Just 3dB higher, and it's now 26mA at 3Vrms. That's almost 9V peak-to-peak, so now you're outside the range of almost any amp powered from 9V, which eliminates some of the better portables. You can see how this starts to take off into the stratosphere.
And I would use it with balanced output amplifier. If your amp has ground all connected, it wouldn't do you any good though. |
Some dude did a small calculations and he said K100 require huge voltage swing. I can't confirm this. Induge me if you can. |
