Originally Posted by earwicker7 /img/forum/go_quote.gif
I'm personally convinced that a high resolution system will amplify the hell out of interference that might not show up on a middle of the road system.
Another fundamental misconception on the way amplifiers work.....why would a high end system "amplify the hell" out of interference and not do the same for music?
Are you saying that your system has greater gain overall than a mid-fi rig?
That can't be right. The same gain is applied to the entire input signal.....gain is simply a question of loudness, and for the most part, system gains are all in the same range, more or less.
Are you saying that your system otherwise has a lower noise floor downstream of the CDP that allows you to hear the interference?
Sorry, but even much lower priced gear is so quiet that one should be able to easily pick up on significant interference. I reiterate--my Marantz SA8001 or E-MU 0404 USB are dead quiet out of their internal headphone outputs or into a CK²III at full volume. No difference between max volume, minimum volume, or with the power off.
Borrow or buy a DMM or continuity tester, and check if the ground pin on the plug of the $$$ power cable that "works" is connected to the corresponding terminal on the socket end. It might be that a shield in that cable is connected to the pin on the plug but not to the terminal in the socket, but that is sort of a long shot.
