Technics EAH-AZ100 - Reviews & Impressions
Apr 2, 2025 at 9:42 PM Post #346 of 364
Lots and lots of fans here for AZLA Origins. AZ 100's are the best all-around package for price by far, but the sound was not as good to me as the Rex5s and the Beoplay elevens, which are the two I kept. AZ 100's were a super close third. I would be very happy with them.
Yep, go for Azla Origin, otherwise due to smaller size and short stems/shallow insertion they can slip out or or lose seal when moving around.
They sound fine for TWS, but still on a muddy side comparing to wired IEMs with good USB or BT dongle, totally fine for not critical listening doing chores around the house, exercising in the gym, etc.
Apr 6, 2025 at 11:12 AM Post #347 of 364
I could not stop thinking about these because they are so, so comfortable. I just bought a used pair from B&H for $200. I'm wondering if they are in my mix, whether they will be the ones I grab, even though others have better sound.
So, I have the Rex5, the Beoplay Elevens, and now the AZ 100s. I figure I'll sell the one I don't use.
Apr 9, 2025 at 11:41 AM Post #349 of 364
No more sound interruption for me with the new firmware, until now. I am using LDAC but set with 2 concurrent connections, so the bandwith may be limited to 660kbps when walking. I experienced just minor pops before the upgrade, like once a day. So I suppose they did improve the connection stability but cannot tell if this will be the case for those experiencing frequent issues.
After more days of testing, I do not think there are dramatic (if any) improvements to the connection stability in 1.030 firmware. The situation with sound interruptions repeated a couple of times. But I do think I can trace the cause each time: crowded buses, cars with people talking using handsfree systems, even a USB3 high-speed data transfer on my computer (with the cable near the source antenna). Is this a more sensitive device than other earphones? Maybe, and for BT sources that are already weak (old BT standards, poor antennas etc) this could be problematic.
Apr 10, 2025 at 5:40 PM Post #350 of 364
Same experience here. Still getting those random clicks and pops after the software update, even with a new pair given by service centre. Will get in touch with Technics and see what’s the next step. I’ve meddled with all the settings that I know of but problem still persist.
Apr 10, 2025 at 6:51 PM Post #351 of 364
I got the AZ100 as I became curious after owning the AZ80. I am not a TWS guy, only use them a handful of times a year on my flights and the odd train journeys here and there. No reasonably priced portable gear can come close to the sound quality of my home system (not bragging, just a fact), so TWS is a necessity to me, and it is not really about musical enjoyment. To me pretty much all of them lack clarity, definition, balance and refinement. I don't like the commercial tuning of overblown and unclear bass, so I don't even want to listen to something like the Sony XM5. The AZ80 was not as obnoxious as the Sony but still had to EQ down the bass for some sort of a balance. Apart from that I quite liked the AZ80, mids and treble were relatively clear, non-fatiguing. Comfort was better than most other TWS buds, but my ears still started to hurt after 2 hours.
Enter the AZ100. I will try to reflect on previous points in the thread, when it comes to AZ80/AZ100 comparisons. First of all, I think the AZ100 is a pleasant improvement on the AZ80 on all fronts, but don't expect fireworks and a revelation. Out of the box I installed the firmware upgrade, so unfortunately, I cannot comment on whether the fw upgrade changes the stock sound or not. The sound overall feels clearer than on the AZ80, a little more refined and a little more neutral. Nice smooth mids and treble with a bit more clarity. Treble is perhaps a tiny bit brighter. Bass is similar, the AZ100 bass is a bit clearer and slightly less overblown in stock form versus the AZ80. I still have to EQ bass down a little bit, but not as much as on the AZ80.
Soundstage size to me is similar. Comfort is a substantial step up. The smaller buds sit in my ears perfectly, I can almost forget about them. I haven't crossed the critical 2 hours mark in one go on the AZ100 yet, but so far, they feel more ergonomic than the AZ80. Seal is also better (I use M/L tips). When I was moving my jaw around with the AZ80 (L tips), I was able to break the seal. On the AZ100 I cannot, and they also feel more secure. Touch control feels a little quicker, ANC is a noticeable improvement versus the AZ80.
I am not experiencing any cutouts or connection issues using LDAC. Have to leave them on adaptive bitrate though (as Technics recommends) otherwise the sound stutters.
They do not get louder than the AZ80, they are pretty much the same. Sometimes I could use one step more above max volume, and I am not a very loud listener. Probably with ANC on, the volume is still fine, I have to wait with testing this until my next flight.
The earbuds and the case both feel light. I like that the case is even smaller, but it feels plasticky and a bit cheap, will see how it holds up.
The reason I use TWS sometimes is ANC and wireless convenience. For musical enjoyment something like the Meze Alba with a Cayin RU7 will do a much better job in every aspect even compared to the AZ100, but the Alba unfortunately doesn't isolate enough on the plane and fiddling with an USB DAC + wires is also frustrating. So AZ100 it is for now. They sound decent, just a bit 'commercial' and not as balanced as similarly priced wired IEMs. For what it is though, I think the AZ100 is a decent offering and certainly an improvement over the AZ80. I would say though, unless you had comfort issues with the AZ80, don't rush with the upgrade. The AZ100 has increased clarity and balance/refinement, but the upgrade is not night and day. AZ80 perhaps sounds a little fuller with even more elevated bass, but also mushier/muddier in comparison. That said, certain people might find the warmer and more coloured sound of the AZ80 more appealing versus the slightly cleaner and slightly more neutral AZ100.
I think, the polarizing impressions regarding bass on the AZ80 and AZ100 mostly come down to having a good seal. With good seal on both of them and bass EQ-d to similar dB levels, neither comes through as particularly stronger or more impactful. AZ80 bass perhaps is a little meatier, but a tad hazier as well versus the AZ100 bass which definitely sounds clearer. If I had to criticise the AZ100's sound then I would say, sometimes it is a bit dry. Coming from much higher-end sound, I do find bass quality underwhelming on pretty much every TWS, but mids are actually quite nice and 'liquid' smooth on the AZ100 as well as the treble. Treble is never harsh, but smooth yet clear. Sound is also fairly coherent, which is a plus. All in all, I think, the AZ100 is a step to the good direction from the AZ80, but not perfect. I welcome the clarity, the fluid smoothness and the tuning intent for a better balance, but I would like to hear an even more controlled bass, even better balance and a little more 'vibrant' character at the same time.
Overall, the AZ100 is a good package, especially if you can find it with some discount. Most of all I like the improved ANC and improved comfort versus the AZ80. Sound-wise, I enjoy the enhanced clarity, but at the end of the day it is still 'TWS sound' in case anyone was wondering. :)
May 2, 2025 at 12:55 PM Post #353 of 364
I am almost sure they dropped bass in Direct tuning in one of the FW releases, they do not sound like they used to. I had to use Treble+ to tame bass down, now it's just fine on Direct. Could explain polarizing views on bass.
May 2, 2025 at 4:40 PM Post #354 of 364
I switched to Treble+ as well and they sound great
May 5, 2025 at 12:33 PM Post #355 of 364
Anyone notice a defect in the right ear piece when ANC engaged? My one made a kind of spinning sound and vibrated in my ear. Definitely relAted to ANC as once turned off it's fine. Except I need ANC. Bought a replacement pair but it's beginning to happen again.....
That said, this time a decent brush of the earpiece seems to have calmed it down for now but worried it will come back. Anyone experiencing anything like this?
May 8, 2025 at 5:29 AM Post #357 of 364
Thanks, so it’s not just me. That is worrying. My second pair are still holding up after a good brush around the earpiece. I’m not precisely sure where the ANC mic is on the earpiece but scrubbed it all and it’s done the job for now. My first one could not be redeemed by cleaning.
The Technics support team are rubbish in my experience. I’ve been trying g for a month solid to buy a back up pair of large ear tips from them for the AZ100 but they can’t provide any. Keep going around in circles and it’s as if I’m dealing with an AI bot. It seems there isn’t a spare pair anywhere on planet earth. I mean. All they have to do is reach into an AZ100 box and take a pair of large tips out and sell them to me but no…..
May 8, 2025 at 6:04 AM Post #358 of 364
Those small microphones are a global issue. I have a Sony WH-1000XM3 that exactly after the warranty period started a loud whizzing in one of the cups with ANC on. After many years without using them, now are working fine... Also I changed two 1More ComfoBuds with exactly the same issue, this was permanent damage. I think the technology and miniaturization are still not reliable enough and there is a matter of luck if your pair of headphones will last many years or just several months.
May 8, 2025 at 6:52 AM Post #359 of 364
Yesterday I got these jewels delivered...I immediately put on my Sednaearfit Origin and they literally fly. I have never heard anything like them...my Rex5 are now in great danger of being sold...
I have bought az100 second time and they are with me as my Aviot te-zx1 failed.
I am using the xs/s tips , some EQ , spatial sound
upgraded FW already .
Best sound to my ears is ANC off
While waiting to find a deal on Rex5 or deciding to buy another te-zx1 , I want to see what they can reach for max SQ
Is there anything/tips/options/special care i can do to improve SQ on AZ100 ?
Layering and separation are a nice bit "way off" a dare say. Far from te-zx1 , comparing holography ( for voices i.e.) on az100 it is simply not there at all, less speed and clarity and sound pressure on change of dynamics is not really comparable
Az100 are bland and a bit anonymous in delivery , range of their qualities falls short of te-zx1 ( metal, prog metal , jazz , post rock.. anything really )
Unless I am missing something ofc
(but second time I get them so )
May 8, 2025 at 9:13 AM Post #360 of 364
Azla Origin tips and I found after the FW update the Treble+ was a good place to start
