I just joined this forum to address a great deal of misinformation regarding the Teac UD-503. There has been all kinds of things flying around different forums and as a former Electronics Tech and currently an Electronic Engineer plus a fanatic High End Audiophile of 30+ years (and a musician and attendee of local classical concerts in a college auditorium) I would like to cover these issues as I have a UD-503 and I have given it a thorough physical examination. I do not recommend tearing one apart just for the pure hell of it. Listen to it. If it's not your cup of tea then acquire something else. I tore mine down because I simply could not believe some of what I was reading. As it turns out, there is reason not to believe some of it.
>THE TEAC UD-503 LACKS REGULATED POWER SUPPLIES IN SOME AREAS: False. Everything in the UD-503 is regulated. Some regulation circuits cannot be seen from the top side of the board, some cannot be seen from the bottom side of the board and it really takes a view of BOTH sides and some tracing to figure out what is going on. The statements regarding this are ludicrous. $30 DVD players can't even go without regulation of SOME sort. The highly delicate IC's would fry; they could never take the ripple. Yes, the UD-503 is regulated.
>THE PARTS QUALITY IN THE UD-503 IS MARGINAL OR POOR: Again, FALSE! No, the parts quality is not "Top Shelf", but nothing at this price point is going to be. The innards of the UD-503 contain excellent DAC's, XMOS, receiver chips, Chemi-Con and Nichicon Muse electrolytics, conductive polymer solid caps and yes, SMD resistors and SMD capacitors. As much as I hate working with SMD parts, they do cost less for the manufacturer AND when properly used are superior to "through hole" parts. The SMD resistors and capacitors are virtually as non-inductive as you can get which is precisely what you want in a digital device. As a hardcore audiophile and Engineer I was actually impressed by the guts. The parts quality is actually pretty damn good.
>THE WIRING IS A MESS: Well, when modular boards are used, there will be wire used as well. Functional construction will require the use of wire. The boards have to make contact with one another somehow. Should TEAC have used in-chassis Blue Tooth? (I doubt any such thing exists but what else should they have done?) I have seen equipment that looked like a rat's nest and sounded like heaven. The internals were not executed so one could sit in one spot all day and admire the precision routing and placement of parts. It is designed to listen to and if needed, to work on. TEAC did an adequate job with the wire routing.
>MODDERS IN CHINA AND HONG KONG ARE ADDING REGULATORS AND IMPROVING PARTS: Well good for them. If they wanted a more expensive DAC they should have bought one. They were doing the SAME THING with the 501. When looking at the circuit boards, the 503 executes it's voltage regulation in such a manner that it does not jump out at you and scream REGULATION HERE!!!!, where the 501 did. The regulation our Asian friends are adding now is about part improvement and the regulating of branch circuits which are already regulated, but they are adding another; either because they don't know or because they think it will be better, which one I don't know. You can add more regulators and better parts to damn near anything if you really want to. When translated I have read that stuff along with "I hear a difference". Of course you do; but is it a difference or an improvement?
>SOUND QUALITY: I have heard some rumblings about sound. I will explain my experience like this: Firstly, I have a $4K analog rig. Secondly, I had, before the TEAC UD-503 a 2015 Matrix Mini-i Pro that had been extensively modded. Mundorf caps, Elna Silmic II caps, M caps, discreet regulators, better transformer. This DAC is supposedly all that and a bag of chips at $520 distributor direct. After I modded it I could not believe the sound. It was so good I seriously questioned if the TEAC would be better (the modded-Matrix did beat a $1200 DAC I had here). I have a pretty solid grip on Hi Res. I have been messing with it intensely for 5 years. After receiving the TEAC and listening, I kicked the turbo-charged Matrix out the door. Believe me; if the TEAC didn't blow my socks off I would have sent it back. It's still here.
>WHAT'S THE CONDITION OF YOUR COMPUTER? While using the Matrix, I discovered my ATX PC computer build had some room to go, even though I thought I had covered everything. I added some filters, added better quality RAM (like for gaming-it sounds better-it is better shielded and has better heat dissipation), I installed a PCIe USB card which used a silicon oscillator for my digital out (silicon oscillators have approximately 1/1000th the jitter of quartz oscillators), I replaced my good quality aftermarket power supply with an even better one (read reviews and observe ripple specs). All of this created an improvement that was not subtle. Big improvement. For Hi Res Audio, a computer is not a computer. Certain things do matter and to a massive extent. I don't care about asynchronous and reclocking or whatever. If your computer is not up to snuff your DAC will reveal it and the TEAC is good enough it will reveal quite a bit.
The bottom line is some people are going to make claims about stuff they don't understand. Some people may even make claims about one product to make them feel better about their own. Some people are just going to complain. If it makes your ears happy, then the company did it right.
Regarding my most recent DAC purchase, I auditioned (in my home) a number of DAC's, (I guess if you can call 2 others plus the UD-503 "a number"). I am not and will not go into what the others were as I am not a "product basher". What I will say is through headphones and through my hi-fi rig the TEAC UD-503 has the best tonal balance, the most detail, the most dimension. The Teac also never fails to satisfy on the level of pure musicality. Due to a large community of local musical talent, I frequently hear unamplified live music frequently. I have even recorded some through the years with my analog open-reel recording rig which has provided some pretty tasty masters over the years. I have transferred these to 32/192. When I play these masters back right off of the reel, it takes me back to the event. When I play the digital masters on the TEAC UD-503 I am taken back to the event as well. Of the DACs I have owned AND the ones I auditioned, the TEAC UD-503 is the only one capable of achieving this. Just a note; of the DACs I recently auditioned, the UD-503 was the least expensive. Taken on it's sonic abilities plus keeping in mind it's versatility it is a bargain with a capital "B". I have heard the price will be going up, so move while you can.
Just an FYI: 200 hours break in.
