rdlhifi
- Dec 8, 2013
as long as it is not windows RT (this is the other version of tablet windows) and written as ordinary windows , then it should have worked
Thank You for the Input Retrias!
Mixed News Guys!
The Good News is the User "Timur" posted a while ago a Rom that solves all my Desires (Gives a Tablet, in this case the Nexus 7, USB Audio and large HDD management Capabilities)
The Bad News is it works only with the 2012 version of the Tabletand Timur is no longer Upgrading nor Supporting his Rom. If You buy a N7 (2013) It will not work....
I just picked up the new Samsung Galaxy Tab Pro 10.1 and it works with my Seagate Travel 500GB USB HD, using the OTG cable. The tablet's stock music player can play MP3 / FLAC from the HD.
My current solution is a Toshiba WT8, 2GB RAM, 64GB SSD + 64GB microSD, Win8.1 running JRiver MC19, micro-USB OTG to iFi iDSD to headphone. Great for traveling. I have a special OTG cable that can charge my tablet concurrently while using the USB function. Being using it for only 2 days. Still have not find a solution to turn off the Auto-Brite function and figuring out how to turn off the screen without going into hibernation mode.
Will you use it with paired with a Home Audio System, or only for Mobile use? Thanks Dan
The only thing left to know is if it will handle large HDD's?
Yes, it can!
Non-stop folder playback with USB Audio Player PRO (UAPP): Music files stored on a 2TB portable hard drive
I have a Toshiba Thrive AT100 with full usb port + very large removable battery 8000 mamps. I play content of 1 TB HD with Neutron Music Player. Works great ....
...so the only way left is installing Autodroid Rom. We'll see if it works like the former Rom...Cheers
Dan
Thats great! Q: Have you tried to connect it into a home audio system? Does it have USB Audio out cappabilities? Thanks!
The AT 100 also has a full HDMI out .... I don't have a receiver for it. But HDMI audio will work ...
