phantompersona
- Jan 31, 2012
Nice, i can't wait to hear what you say about them when you get them ClieOS.
i wonder if the rifled metal bits are unpleasant in the ear ?
ordered h-100rr (ebay, by asking the seller, he says ships 10th oct... bit concerned with 5 feedback and advertising registered post as 'express', but why not i guess)
You will be so happy about ordering this. I just got mine and, although still a little early to give any real in-depth impression, I have to say I am really impressed. Granted I haven't heard K3003, I think it is one of the most balanced and most harmonic of any hybrid I have heard - just a big WOW from me atm.
*drool*.No, I have the green ringed version, not the rifted version. I think those ring are metal as well, as the housing does have a bit of weight on it. The overall build quality is good, but I can see some minor area that can be improved further. But sound wise, I don't think this has any problem competing with IEM on the $300 range.
Comply 400 series should fit it. I suspect Monster foam should be okay too. They do however include foam filled hybrid beside the regular hybrid. Do be careful when removing the eartips as they are very tight on the nozzle.
