Going to sleep now so can't find the link but check my review (first P review) and at the end of it there are my EQ settings.Can you share your EQ settings? Having trouble finding them. Thanks
T+A Solitaire P planar magnetostatic
- Thread starter thinker
Received and tried the ultra wide pads but I found the differences quite subtle. Less impact than my EQ settings. So I reverted back to the stock pads and the simple EQ profile below. They sound excellent to me like that and this is what I will go with for now.
that's interesting man. I swapped back to the stock pads after reading your post and the differences I hear from the ultra wides are quite big! I'll give your peq settings a go when I have some time this weekend.
I thought all rigs showed this dip at 9k and it isn't indicative of the actual FR.I based that on this chart, which shows a pretty narrow dip in the treble, so I'm offsetting that with a narrow peak instead of a shelf.
Really? I checked a few other charts and most show a dip there indeed, although not as extreme. I'll try it without that correction. That would make the profile even simpler, just a mid range bump.I thought all rigs showed this dip at 9k and it isn't indicative of the actual FR.
EDIT: I removed the treble peak. I don't notice a large difference, as it impacted a narrow frequency range. I will limit the profile to a mid range bump of 3 dB.
When I say that the differences are subtle I mean that relative to what EQ can do. Pads can only impact the FR by a few dB here and there.that's interesting man. I swapped back to the stock pads after reading your post and the differences I hear from the ultra wides are quite big! I'll give your peq settings a go when I have some time this weekend.
nwavesailor
- Nov 14, 2009
I suppose I'm happy with my stock pads and a little EQ.
At $320US, I'm not too excited to buy the UW and perhaps only experience a subtle change.
I think I am looking to solve a problem I don't have and to just throw $$$ at the P's.
I don't have the P anymore, so I cannot confirm if this is what I still prefer. Here they are, at the end if the page. I think 1, 3 and 6 are the important ones. 4th in case you feel the lower treble is too hot.Can you share your EQ settings? Having trouble finding them. Thanks
https://www.head-fi.org/showcase/t-a-solitaire-p.24843/
nwavesailor
- Nov 14, 2009
When asking about the UW pads the dealer said there were 2 versions, closed or semi open?
FooFighter
I can only speculate that the dealer meant the regular pads and the ultra wides.When asking about the UW pads the dealer said there were 2 versions, closed or semi open?
The ultra wides can be identified easily by the perforation.
nwavesailor
- Nov 14, 2009
Waiting to hear from T+A.
The dealer 'thought' there were 2 UW options (one being new) but you are probably right, standard pads and UW. Still not sure I'm going for either at this point.
nwavesailor
- Nov 14, 2009
Thanks!
The owner / consumer often to know more than the dealers.
It is unfortunately not like ADI-2, there is no adjustable limit for when it will be activated. As far as I remember, once loudness is engaged it is always active for the whole volume levels, though the level might slightly change.@HA200 owners
While I like the loudness function I was hoping that it is adopting itself based on the volume and thus raising certain frequencies like bass only at lower listening volumes and returning to a flat response curve after passing a certain volume threshold.
As far as I remember RME ADI 2 is doing that...
But HA200 seems to be pushing up the bass frequencies no matter what the volume is like I know from my car stereo systems from the past leading to a V-shaped sound signature.
Is that how it is supposed to work, so the loudness level (minimum up to high) should be manually adjusted depending on the listening volume?
Dynamo5561
Today I was able to demo the SolP. After that I sold my P-SE to upgrade to the P-model.
I want to now create a custom cable before it arrives. Can anyone check if 7,5mm diameter HD800 connectors will fit into the SolP? I know about the length issue, I just want to understand if 7,5mm is thin enough for the SolP.
Additionally, does anyone know if they do proprietary wiring like on the P-SE model? But I guess as it is just 2 pin there should be no issue.
Thanks!
Thanks!
OneEyedHito
They fit to my understanding but not to my actual experience. The cables are interchangeable from hd800 to SolP.Today I was able to demo the SolP. After that I sold my P-SE to upgrade to the P-model.
I want to know create a custom cable before it arrives. Can anyone check if 7,5mm diameter HD800 connectors will fit into the SolP? I know about the length issue, I just want to understand if 7,5mm is thin enough for the SolP.
Thanks!
