Earwax
- Aug 31, 2003
Do you have a source splitter? I have used this from parts express, but you may feel better about getting a high-end vampire tap.
Originally Posted by Earwax Do you have a source splitter? I have used this from parts express, but you may feel better about getting a high-end vampire tap. |
Originally Posted by Kevin Gilmore gsferarri's second picture is the correct one. You need 3 isolated jacks. If i was going to build it i would use the chassis mount Neutrik gold plated jacks. Then you need a 3PDT toggle switch without the center off. (ON None On) like this http://www.electro-nc.com/miniature/minp3843.pdf mouser part number 690-A323S1YZQ On None On Other versions with center off available. Depends on what is in stock. Buy the best switch that is in stock. (my preference from other vendors would be CK or Alco) Then a nice solid aluminum box to put it in. Like a Pomona. But really anything will do. You will need to punch the holes for the jacks. Of course 2 wire tails and a switch and one jack works too, probably better because of less connections. The digikey part number ckn1037-nd is probably the switch I would use. |
Originally Posted by Edwood Source? This switchbox is for switching between the headphone outputs between two different outputs from two different amps. -Ed |
Originally Posted by rickcr42 you guys are really clueless and need to do some actual research before you become self appointed audio engineers. do you not realise there are not a small number of new members that don't know squat and read these types of posts from members with a high post count as if it were gospel ? |
Originally Posted by gsferrari What is the difference between :- ON - OFF - ON and ON - NONE - ON |
