laxx
- Sep 18, 2006
Hey guys. I've been wanting to make a switchbox for quite some time now, but I have a few questions regarding a rotary switch.
I want a 3 input 1 output switchbox (which I can later add both more inputs and outputs if desired) and I don't think I can use a regular switch. After checking out some rotary switches, what do you guys think is better?
2 Pole X throw/way rotary switch
2 Pole (R/L Signal) would be attacked to the rotary switch while the grounds are connected to the chassis
4 Pole X throw/way rotary switch
4 Pole (R/L Signal and R/L Ground
I think they basically work the same since the ground lug on the RCA jack is connected to the chassis anyway. Would going with the 2 pole perform the same?
Thanks for anyone who reads this. =T
