L-Train
- Jan 2, 2011
Well I ordered a set of pcbs and 3 sets of components, hooked one all up and I got nothing...
Hi GameTechUS,
Sorry to hear about the issues you're having with the board, I hope I can help make it work.
Can you compare your stuffed board to the picture of mine I posted earlier in this thread? Ensure that all ICs are oriented correctly, especially X1 as that should be oriented upside down with pin 1 in the top right corner when viewing the board right side up. Also note that FB3 and FB4 are installed horizontally rather than vertically.
With the power off, check continuity between the positive leg of the bypass capacitor near each IC and the IC's pins that are connected to 3.3V (refer to one of your unpopulated boards or the PCB renders on OSH Park). If these are okay then check that the regulator is outputting 3.3V by measuring across C2 and check that there's 3.3V across the capacitor near each IC.
Check that there's continuity between the left side of R5 and pin 2 on U2, and between the right side of R6 and pin 21 on U3. If these are okay then the two chips should be getting a master clock signal from the oscillator.
Also check the idle current draw of the board alone when powered outside of the SNES, with the /RST pad connected to 5V and nothing connected to SDIN, BCKI, LRCKI, D+, and D-. If I remember correctly I measured ~25ma during my testing. If yours is much higher then you might have a short somewhere, if it's lower check that pin 6 on U1 is outputting 3.3V and make sure that pin 13 on U2 and pin 9 on U3 are soldered correctly and have continuity.
The D+ pad should be connected to the center pin of your RCA jack and D- should be connected to the RCA jack shield. Don't connect D- or the RCA jack shield to the SNES' ground as that would ruin the isolation the transformer provides.
Would you happen to have high resolution pictures of your stuffed board?
I appreciate your criticisms of my PCB and will remember them if I decide to release something like this again in the future.
L
