Thank you. What about iPower2 then? Can it deliver more than 4A while running on 230V?If the PSU will deliver 5V/1A at 100V, it may actually deliver 2A while running on 230V
Moondrop Venus, 100db 18 ohm. When connecting a linear power supply to Zen can from AliExpress, it adds bass, but the sound becomes harsh. With ipower2, there is less bass, but the sound is smooth and pleasant))
Became interesting. I don’t quite understand English, should I connect the plug itself?If it is possible to try, let's isolate causes. Could you plug in the iPower in addition to the linear power supply and take a small wire to make a connection between the barrels of the DC connectors (iPower ground to Linear Power ground). See if there is a change in sound with and without this connection.
I found it here. Well, this one might be better being medical grade - idk what it means but it should be more reliable.For similar price you can find this one 5V/6A:
https://www.meanwell-web.com/en-gb/ac-dc-medical-desktop-adaptor-with-3-pin-iec320-gsm60a05--p1j
https://www.cybernetman.com/blog/medical-grade/I found it here. Well, this one might be better being medical grade - idk what it means but it should be more reliable
100mV Peak-Peak switching noise
That meanwell 5V/6A medical PSUs have in general lower ripple and noise measured parameter than non-medical. If the spec allows maximum value of 120mV p-p, it is measured at around 60-70mV level (ripple and noise measured at 20MHz by using 12” twisted pair terminated with 0.1uF and 47uF capacitor ).
Audible noise, for me possible to detect only at +18dB gain level over 12oclock (which I don’t use) is lower than stock ZenCan 5V/2.4A PSU, but definitely higher than iPower2 (which brings no noise at all I’d say). I use non-medical 5V6A meanwell and I’m happy with it
I'm with my new 5.1v 4A from amazon and I can't say I can hear a difference with my headphones - HD800S, HD650, Focal Clear MG, Ananda and have not tried Sundara.
But I'll kep it for piece of mind. I honestly think I won't hear a difference chasing a linear power supply so I won't chase this dragon.
My 2 cents really as a consumer.
