iPoodz
- Jan 23, 2009
|joker|, thank you so very much for the thorough help you've provided! I really felt welcome by your response to some of my noob questions
I'm getting more comfortable with the idea of buying ADDIEMs from ebay, after just a little more investigating on the cable noise [I read many reviews that indicated that the ADDIEMs could be rendered unusable if one moved while listening, and I don't know how much of that is internet hyperbole].
The Lenntek seems very cool, especially due to the angled plug! I've heard good things about the V-Modas[which these are allegedly similar to], and I might end up buying this later in the month if I run into more money...
koven, alas, I don't have too much money at the moment, but how much of an increase of quality would it be to say the NE-7M? I could hold off, but I'm unsure of how much better they would be.
bixby, maybe you can help me with my question about cable noise/build quality. Do you find it to be a big issue, or should I just put it out of mind?
bba1973, thanks for the advice on the amp, I may consider that down the road.
To everyone: the biggest complaint about the UHP336 was the protrusion from the ear. bba1973 said that if you wear it like so then it's not really an issue. The image suggests the same. Should I reconsider not getting these, or is the ADDIEM SQ better anyways?
Hopefully I'll make a decision tomorrow, thanks again for everyone being so patient with me!
