UltMusicSnob
- Aug 14, 2013
From an earlier post, resample.exe is the program found at the link in your signature? If B.flac replaces the 192_24 I was originally using (yours with lower level to avoid clipping), then this adds another treatment difference, as my original was created with iZotope 64-bit SRC, using these settings: 32 db filter steepness, 500000 max filter length, 1.0 cutoff scaling, 175 alias suppression and 100% prering (from the Soundforge 10 conversion interface using the iZotope tool).
Okay, here's A vs. B. My subjective cue to listen for was soundstage depth/width.
This was a planned set of 20 rounds. I went very slowly here, lots of 10-30 sec silences between my 'play' clicks.
stv014, I read some of the content in the links in your signature, holy cr-- it's deep. Are you in the business as a professional, or just a really informed listener?
OK, here is a set of new files, this time in FLAC format to reduce the download size. You can convert them to WAV first if you want to. The files are now attenuated by 0.63 dB to avoid clipping. I used the following command to simulate the "original" 192/24 file with attenuation:
I do not reveal the identity of all the files yet, so only listen, and do not analyze them.Code:resample.exe -k 0.000002923047 -r 192000 -f 3 -ff 0.5 -fw 0 -fl -2400 -g 0.93 Test_File_Foobar_Redbook.wav test_192k.wav
However, B.flac is the 192/24 resampled file, so you can compare the others against that one.![]()
