JVC HA-S680, around $80, eBay
Or the cheaper JVC HA-S500
Note that HA-S500 is on ear, not over. It has a V-shaped sound with quite decent bass. Super easy to drive.
So I've been doing a TON of research, and I think my final list are the: NXV XPT100, UE6000, JVC HA-S680, Takstar Pro 80, Takstar HD6000
These are in no particular order, but I'm really favoring the top three since I can't find enough info comparing the bottom two to the others.
I don't have an amp, but EVENTUALLY I'll purchase the Fiio E6. All of these are around $80 or less... which is the best? Unless you guys have another pair of headphones I don't know about.... Thanks!
Edit: I realize that the NVX aren't really "portable", but I've decided to buy a good, cheap IEM (like Xiaomi Pistons) and use those on the go and use the headphones when I'm studying in the library. So "portable" in the way I meant before isn't really necessary anymore. Also forgot to mention that I am still strongly considering the Sony ZX700
At sub-$100 ($70ish) your choices are very limited. The only pair of headphones I have experienced on your list is the Logitech UE6000 because I am interested in headphones from the $200-$400 price range. I only reason I have experience w/ em is because they retailed at $200 and was reviewed favorably in comparison to other top-end closed, portable ~$300ish headphones.
They are actually currently on-sale $70 at tigerdirect. I don't know what you are waiting for. They are the perfect pair of portable headphones with a lot of extra features, fits into your lowlow budget, and probably better than anything else you can get for that price. The thing is a lot of the more budget headphones may be reviewed well for their price but they were released at the low price. The UE6000 was reviewed as a good value for sound at $200... so at $70, it's a no brainer lol.
The Xiaomi Pistons will probably break in a few months. Just skip it & get the portable UE600 or add $30 to your $100 budget lol & see if you can find nicer headphones. you don't really need to research anymore lol, the options under $100 is pretty limited, so when a $200 pair of headphones that is reviewed to be good sound for $200 drops down sub-$100... IMO. hahah
How much do they leak? I plan on using these in some very quiet environments and don't want to disturb anyone.
does anyone know how they compare to the NVX? They are pretty much the same price and I've read fantastic things about their build/sound quality and accessory list.
Guess I never thought about it that way...
In that case, the Monster Diesel Vektr are the same price and I saw those featured in the winter guide. Which one do you recommend?
Yea I understand what you mean, the only thing I am concerned with is that people have stated that they don't work or sound well with non-apple products... I don't know if it is just the cable or the headphones themselves.
I only brought up the monster because it was in the headfi winter buying guide. The other one I am looking at, that is selling for $100 on newegg (missed the $60 black Friday sell) is the Martin Logan Mikros 90. Do you have experience with that?
