bigshot
Sorry, I was referring to Bansaku
I'd sure like to see you detect a difference of 1dB in a channel with dynamic music in normal listening conditions.
Doubt? Somebody bragging on the internet? Perish the thought.
In highly compressed music you might be able to hear a 1dB difference between channels with direct A/B switching with a balanced sample. In dynamic music perhaps it would take 2 dB. But in the real world, if you sat down and put on your cans and someone played you a CD with one channel +/- 1dB, I don't think you would notice the imbalance at all. I bet it would take at least a 3dB difference.
I REALLY don't believe that you can tell when the wires of your headphone cable are plugged in swapped left for right. If you can, your cable is defective.
P.S. I think you have normal human hearing.
Ok then, just because YOU read it somewhere on the internet doesn't mean it's correct.!
I am not bragging, I am stating a FACT! My current setting in Pro-Q is -1.79dB on the right, and I tuned that to the EXACT decimal listening to a mono source and a 20Hz-20KHz sine sweep until the sound was balanced to my ears. With Audio Midi and my (former) iDAC all I could do is adjust in 1dB increments and at -2dB I could hear the difference, hence why I switched to a professional grade plug-in.
All I was stating is that I can clearly hear the difference, challenging the " so called fact " that people can't hear a change lower than 3dB. I can, and I know others probably can as well.
Ok then, just because YOU read it somewhere on the internet doesn't mean it's correct. I have read that the Earth is flat, and Elvis is alive and well living in the Greek isles. It doesn't be-front me if you don't believe me, it just makes you look like a pompous ass who thinks they can tell me what I can and can not hear. Bet away, if you lived in the Edmonton area I'd gladly take your challenge and wager extremely high just for the satisfaction that I wasn't proved right, rather that you are are proved wrong. Numbers on the screen don't lie, my ears don't lie, and neither do I. And for the record, the stock Meze cables (notice the plurality) are no different than my custom made, and it also makes no difference if I turn the cans around. The same goes for my HD600 with stock and aftermarket cables.
End of conversation; I won't indulge your arrogance/ignorance and piss poor attitude any further. You are incorrect, deal with it and move on!
being suspicious comes with the area. don't take it personally. between how this sub section naturally attracts skeptics, the fact that this is internet, and literally legions of people claiming to be able to do things in audio forums they never in lifetime would actually be able to do, it does create an environment where trust isn't easily gained.I am not bragging, I am stating a FACT! My current setting in Pro-Q is -1.79dB on the right, and I tuned that to the EXACT decimal listening to a mono source and a 20Hz-20KHz sine sweep until the sound was balanced to my ears. With Audio Midi and my (former) iDAC all I could do is adjust in 1dB increments and at -2dB I could hear the difference, hence why I switched to a professional grade plug-in.
