Stefan AudioArt Equinox Sennheiser cable repair help
Jun 25, 2015 at 6:29 AM Thread Starter Post #1 of 2
djbnh
I've reached out to Stefan AudioArt a number of times by phone / the company's website for help in repairing one of their Equinox Sennheiser HD650 headphone cable replacements, but the company never calls back / replies. I'm wondering if any DIYers out there might be of help. I have an issue with the Equinox right channel working intermittently, it's seemingly a problem with the right Sennheiser plug connector (I can wiggle the wire near the connector and I get sound.) Suggestions are appreciated, thank you.
Jul 2, 2015 at 3:32 PM Post #2 of 2
Did you get this squared away? Double check with the stock cable, sometimes the little spring pins in the HD600/650 can get loose over the years and need a little tightening. If the stock cable works fine, the cable should be easy to repair, just have to replace the connector with a Cardas or Furutech, and might as well replace the other side to match.
