Thanks, it wasn't really "easy" per se just "doable". The 507 is capable of intervention in this manner due to its modular construction. I have since fractured the headband and will have to repair that as well. I bought the 507 for durability, so it is a disappointment that they are so disaster prone. My old original Lamdas have had much better luck, even though they are ancient by comparison. I am using the 507 earpieces currently with the original Lambda headband. The strange thing is, I like the original Lambda headband better than the 507 headband, less pressure and more ideal seating.
I am enjoying them very much, listening to them right now.
I was going to do them over with a different mylar "stretch" and a thinner coat of anti-static material. However, haven't had the time or inclination, and they sound great the way they are, so why argue with success? The "new" mylar seem pretty durable so far as well: Normal bias outlet with DIY vintage Stancor transformer (modified SRD 5) hooked up to Manley Neo 300b Preamp, sounds great. I will have to open them up and check out the mylar someday to see what it looks like.
I have another rig in another location, but haven't heard anything at shows so far that would make me believe that I could improve my sound in any meaningful way over either rig. If I did find something I thought was better, I would consider buying it.
The only problem with my setups is they are completely unique and non-commercial, so they don't really do consumers any good unless they want to try their own hand at DIY experimentation. For some strange reason, a lot of my audio stuff winds up that way, even though I am a mediocre and dangerous DIY type, I ruin as much as I improve.
