TominJapan
- Apr 5, 2014
just got my new Stax 2170 nice... now it seems the fuse is broken as the amp does not power on and I can hear that there is a loose part inside the amp. I tried to remvove the four obvious screws two on the front and two on the back panel and one at the bottom... can not slide it out by pushing the rear. Do I need to remove the volume button? if yes....mmm.. how do I do that. Any help is appreciated probably very simple but cant figure it out...Thanks
