So, some technical considerations. As a general rule, the output stage of an amplifier produces the most distortion because it has the widest voltage and current swings. It appears the OTL uses resistor output loads, and you say the Guerra uses inductor output loads. Here's the issue with both those approaches. Electrostatic headphones resemble a capacitor (more or less) in parallel with a resistor (which represents the power lost from producing audio output). This means that the headphones are very high impedance, particularly at low frequencies, which is where the musical signal has most of its power (approximately half the audio power in music lies below around 300 Hz). A resistor load has to be significantly lower resistance than the headphones. An inductor load has its lowest impedance at low frequencies (rising with frequency). What this means is that the vast majority of signal current generated by the output tubes is burned up in the resistor or inductor load, while only a small fraction of the current actually goes to drive the headphones. Thus the output tubes have to work much harder to drive the headphones, resulting in significantly higher distortion, as well as decreased drive capability.
For electrostatic headphones in particular, this means the best approach is constant current loads, because a good constant current load wastes essentially NONE of the signal current, so a much higher proportion of signal current goes to driving the headphones (some is burned up by the feedback resistors, if any). Result - the output tube doesn't work nearly as hard, distortion is reduced and drive capability is improved. For example, substituting constant current sources for the resistor loads in the SRM-T1 doubles its drive capability. There's good reason that all the Stax amps designed since the 1990s use constant current loads, as do all of the Gilmore amps (other than the all triode design, which was the basis for the GES).
