Thanks.
I actually found your instructions in another thread and followed it last night. One problem I had was determining what pins 2, 4, and 5 where in the headphone connector; pin 3 was easy since it is in the middle
. It changes of course depending on whether or not you count clockwise or counter clockwise (when looking at the connector from the front panel). Unfortunately the manual did not help answer this question. I had to try and figure it out on my own. If I counted clockwise adjusting the dc balance pot didn't seem to change the voltage reading. Counting counter clockwise seemed to work. I hope that was right, but if not I'll catch it tonight as I wasn't able to get everything zeroed last night.
One embarassing thing is that it took me over an hour to figure out that each channel has it's own dc offset pot. I couldn't see the other one because it is under the large black wires that run to the volume control
. Well, that's my excuse anyway.
I was able to get the left channel zeroed without much drift. I never was able to get the right channel zeroed without drift between 0.5 V and -300 mV. And that was the hard part. Every change induced fluctuations that lasted minutes! And it took me a while to figure out that you only need to adjust the pots by minuscle amounts; and I mean minuscle. After messing around with the left channel for a while I figured out a procedure that seems to work: adjust the dc offset until it close to zero, go back to dc balance pot and adjust it a little, then go back to the dc offset and get it close to zero. Keep doing this until both pots are close to zero and then start the fine tuning. I found this necessary because I'd get the dc offset set only to find that the dc balance was way off.
This was a painful experience. It will be even more painful if I have to do it again because I biased everything using the wrong pins
! Then again I'll start to become concerned since adjusting the pots using a different counting direction for the pins didn't affect the voltage.
EDIT: I also noticed an appreciable difference when measuring voltage between pin 3, or pin 2, and ground depending on where on the chassis you put the probe. I decide to use the external ground post.
