Jun 24, 2012 at 1:37 AM Thread Starter Post #1 of 2
Stevebobwe
Received some Lambda Pros and I'm having an issue with the right can dropping out. I'm sure it is an issue with the cable because in one specific location if I kink the cable a bit it fixes the issue. Does anyone know where I could pick up a replacement cable, or anyone who would sell me one? I do not believe they would be difficult to replace. Thanks.
Dec 16, 2012 at 1:28 PM Post #2 of 2
Hello Steve,
I would like to know if you found a source for a replacement cable for your Lambdas. I have the same issue with mine, but what's not helping is that they are normal bias, hence i need a six-pin one. These seem unobtainium.
Thanks for any info,
Joris
