Keithpgdrb
Sponsor: ZMF Headphones
- May 22, 2008
I've had my stax setup for a while, and I've always felt that the left side was slightly weaker. I blamed it on my amp for the longest time, but It may not be the problem. I would like to find the problem once and for all. First, I would like to rule out or confirm that its the stax setup.
I am using an srd7sb energizer with my amp, and sr-lambda normal bias cans.
Is there a way to test both the energizer and the cans to see if the signal is balanced properly? I have tested resistance on a pair of sr5nb before, so I assume that will be similar. But what about the energizer? I'd love to find out if its working as it should.
Here is the pinout diagram that I have, without the nb bias pin.
Thank you in advance.
