STAX headphone amp problem.
Jan 26, 2014 at 12:11 AM Thread Starter Post #1 of 11
tankteh
Hi. I recently purchased a STAX SR 3030 system and I have noticed something strange. I have purchased this same amplifier in the past as well as a 323a and 323s. When I turn the left channel knob, I usually feel grinding and I'm pretty certain that it is uneven. Is this common with STAX amplifiers? Everyone I've owned was in near mind condition, and still I had this same problem.
Also, I purchased this 3030 system not knowing that is was the 100v. model. I live in the Chicago area. Is it important that I get a step down transformer? If so, why and could someone link me to one? Not sure how they work.
Jan 26, 2014 at 10:06 AM Post #2 of 11
Hi
If it was me I would just try plugging it into 120 it is not that much different.
But here is a link to a transformer I would get the 300 watt even though the 100 watt would probably be enough
http://international-electrical-supplies.com/transformers12.html
Jan 26, 2014 at 11:59 AM Post #3 of 11
They don't sell that one.
Your answer wasn't very clear. Do I need a step up transformer? Will it harm the am if I don't use one? Also which side would I plug the amp into?
Jan 26, 2014 at 3:45 PM Post #5 of 11
Yes I bought it from yahoo auctions japan.
Can I use the amplifier without the transformer for right now, or will it cause damage? It sounds fine as it is. I just hope it's not shortening the life.
Jan 27, 2014 at 5:03 AM Post #7 of 11
Get a 120V to 100V step down transformer to ensure you aren't running any part of the amplifier close to its voltage limits. They aren't expensive.
Jan 27, 2014 at 5:31 AM Post #8 of 11
I agree with John, better to feed that amp the proper voltage.
You may also want to do some checking, but should be able to change some internals on that amp to run it natively on 120V.
Jan 27, 2014 at 12:22 PM Post #9 of 11
Here is another transformer on E-Bay
Easy to use a input switch 117 or 100 and it has a output for 117 and 100
http://www.ebay.com/itm/1000-Watt-Japan-USA-Voltage-Power-Converter-Transformer-100-Volt-117-120-Volt-/121254451077?pt=LH_DefaultDomain_0&hash=item1c3b541785
